Got the decals on now and Ive started to get the final bits fitted . The exhausts have been drilled out, painted and fitted and the undercarriage is now in place.Using wire Ive added some brake pipes and the sprung hinged linkage that closes the inner doors when the undercarriage is retracted as the tyre hits it . Ive sprayed the exhaust and gun staining and the rest of the airframe will be getting a pin wash to highlight the few panel lines and control surfaces.Oil wash now on and drying . I used dark grey for most of it and some dark brown round the engine , once this has dried ( tomorrow ) its just a case of cleaning it up , adding the aerial and canopy and its done , cheers tony
Cheers andrew , its not often I manage to complete a GB in the time frame!
I thought I had the record with the B58 Hustler for the four engined bomber GB a few years back , it crossed the finish line a year after the end! Youve broken that record by two years ! ( so far !) :smiling5:I've still got three StuGs on the go from Bob's StuG GB starting back in January 2020!!! :smiling5:
