The Bf109 had automatic leading edge slats, these extend naturally on the ground as there is no air pressure to keep them in, until they are pushed back up manually. Automatic slats deploy automatically when the angle of attack increases (negative pressure or the 'lift envelope' moves forward towards the leading edge), energising the boundary layer or air flow over the wing surface. This serves to delay an aerodynamic stall (or loss of lift-producing airflow over an aerofoil), and to increase the effective angle of attack of the wing (by increasing lift coefficient). Another example of automatic slats is the system on the Douglas A-4 Skyhawk. I believe that it was common practice for Luftwaffe ground crew to push the slats in when the
aircraft was parked. I think the colour beneath the slat was the wing surface colour. I'm sure Stona or some other Bf109 enthusiast will confirm or otherwise.
See here for some detail into the workings of the slats: The 109 Lair- The Online Source for Messerschmitt 109 information
As for the flaps, they appear to be plain flaps, but split with radiator flaps fitted, the operation which depends on the version. I believe they were manually operated via a linkage controlled by a wheel on the left side of the cockpit wall (unsure whether this was via a cable or chain). They would probably stay up on the ground, as opposed to hydraulic flaps which droop naturally over time as hydraulic pressure is lost. Pictures show the flaps drooped during maintenance however, so I guess it depends how you want to display your model. Again, someone with better knowledge will advise no doubt.
A picture of a 109 flap showing colours on this link:
http://m9.i.pbase.com/o6/72/722972/1/79470009.UWtwEoeF.DSC_3759.jpg
Hope this helps you Colin. You probably are unable, like me, to read German so those manuals in the link from Allyne help but are not easy to use.
