Thinking of buying a new airbrush...
Sprue42
Hi Guys, I am not new to airbrushing, I have been using them for over 50 years. Most of them are that age too! Got my first DeVilbiss aerograph when I was around 17. I was also lucky enough to be involved with Morris and Ingram, who were the early UK distributor of Badger Airbrushes and acquired several of their early airbrushes. Along with a few others that were around at the time.
I have used airbrushes both for work and hobby over the years. My DeVilbiss airbrushes are all gravity fed but have very small paint reservoirs machined out of the body. Ideal for small detail application of high pigment viscous inks and solvent-based paints. heavier paints will clog it and require too much air pressure for fine work.
The badger and Paasche airbrushes are fine for use with enamels. All are bottom/side feed or external mix airbrushes. I used them on and off for years but have not done any amount modelling with them in decades.
Now I am coming back to the hobby I am looking for a decent double action brush that has a decent size gravity cup that will handle modern acrylic paint without having to increase the air pressure too much. I am looking at the Iwata Eclipse HP-CS which seems to fit the bill. Having never used or even held an Iwata brush I would like the hear your opinions on my proposed purchase or hear any recommendations for other airbrushes.
Ralph.
Been using my Paasche VL for over 40 years....never had a clog and I only shoot solvent based enamels and lacquers. Replaced the needle , air cap and tip once.....problem free if you stay away from latex and acrylics.
Now I am coming back to the hobby I am looking for a decent double action airbrush that has a decent size gravity cup that will handle modern acrylic paint without having to increase the air pressure too much. I am looking at the Iwata Eclipse HP-CS which seems to fit the bill. Having never used or even held an Iwata airbrush I would like the hear your opinions on my proposed purchase or hear any recommendations for other airbrushes.
Ralph.
You won't go wrong with the Eclipse HP-CS in my opinion.
Iv'e been using one for probably 15 years now, and am very happy with it, not that I am particularly good with it lol.
It is better than my old Paasche, but I don't like bottom feed.
A lot has been said for Harder and Steenbeck, but they are pretty expensive though.
I have the hp cs and find it nice to use ,i was using cheapies before that so cant compare it to anything else really .
I have a H&S and an Iwata. I prefer the Iwata. I would definitely endorse the Eclipse HP-CS.
I don't own one of their airbrushes but have been using Iwata products for around 30 years and would say anything of theirs is a solid purchase.
You ask for other recommendations so I'd suggest looking at the Mr Hobby / Creos range to see if they have a model that suits your needs. Made in the same factory as Iwata they share some parts and design features, but generally cost a little less.
I bow to everyone else's knowledge. Only used two, (in 10 months). One a really cheapo Timbertech I was gifted the other I acquired recently a H&S Ultra 2024. Superb AB. The settings for newbies like me are excellent. Seems to get good positive reviews from experienced users!!
If you're looking for something in the budget range, you could do worse than Gaahleri..... They're pretty new but have a search. There are plenty of YouTube and other reviews.
I have been using one for about six months and love it!
I have these in my stash - learning the ropes with my humble Neo but both it and myself are struggling at 1/72
Which one would you pick for 1/72, 1/48, 1/35 and 1/32? Is there a one size fits all?
I would also like to ask also how I can employ this because only one end fits my Neo or my compressor but not both!
I have an Iwata eclipse SBS. Great airbrush. Works flawlessly. Very easy to strip and clean. No issues I can think of.
As to fitting the hose to the airbrush, you can get adapters that screw on the brush as the manufacturers all seem to use a different hose fitment. Look here.
https://www.amazon.co.uk/ABESTAIR-p...5&psc=1&mcid=e391eb4fe0513c96af019a202239c5ed
thanks for the link - there’s a lot of options there. I see your airbrush is no longer available - it’s now
Iwata Takumi Eclipse Side Feed​
Not a problem for me, I see no need to replace it. I’ve only bought one needle as a spare since I purchased it a good ten years ago, and full spares (every single part) are still available from graphic air suppliers elsewhere. It’s a great robust modellers tool.
Like these
Yep, I’ve got the unused ones in a drawer somewhere as well ;) I bought them for my Aztec brush, which has a really small air hose connection compared to the standard 1/8 bsp fitting.
So how does my Eclipse compare?
Dear Sprue 42,
I'm sorry I cannot give you a direct advice as I have two a/b, both Badger's and non gravity fed.
You will find many threads here on the forum about choosing an a/b; just type "airbrush" in the "Search" window, upper right corner on the homepage, select "search title only" and then click on the "search" button.
Hope you'll find what you need, and I'm pretty sure you will. :thumb2:
