Trumpeter German navy destroyer Z30
Bob matety you say hms exerter arrives today wow how many shippy kits have you now ? a whole navy i should think
chrisb
Hi Chris, yes doctor I have a addiction lol. Yep I have a good few floaty boats.
I have a building plan with the next one ready and waiting. Honest guv. Should be building more and posting but of course my mum comes first.
Might be fighting back Bob, but she’s looking pretty good from here. Moulding boxes out of that many parts does seem a little weird though.
Thanks Tim. I assume pre slide moulds. Took ages to clean up the parts, then try to get them correct then glue. Fiddly.
Long & skinny, the better to go fast. Looking good.
Same holds for ships too.
Afternoon tiny bit more done, calming down a bit now after mum. So Julie told me to glue some plastic together!
Added the prop shafts and support brackets. Needed some filler.
Resisted the urge to fit both rudders until just before painting. Knocked the last one of Fletcher as it was fitted early. Seems I am finally learning by past mistakes!20240412_160809.jpg
There is also a prominent seam for the boot topping, need to get rid of that too
HI Bob matey great to see you also back at the bench after your poor mum incedent so keep at it an get better an cheer up an can we have a full size pic of your ship there
chrisb
chrisb
Thanks Chris, we are seeing the undertaker on Monday. Not looking forward to that, but got to be done obviously
Good to see you again.
That marking for the boot topping is a bit over the top lol.
Great to see you cracking Z30 Bob, she is looking really good.
Glad you feel able to go back to the bench. I'm sure it is the right thing to do.
You're making steady progress and she's starting to look the part. Older kits almost always require a lot of extra work but the effort it worth it.
Thanks Ian, thought it was for the crew to stand on to paint the hull lol
Appreciated ta very much!
Hi Jim many thanks. Agree the difference between this and the latest kit is huge, thanks to slide moulds
Well folks, still about.
To get certain things of my mind, at least for a while I attacked the terrible moulded line on the hull side. See last photo.
So ideal chance to test the dspiae small electric drill / sander I got from John.
It has three speeds, so the top line shows it's at 2nd speed and the bottom line is the battery charge. It comes with a single drill but not the attachments or sanding discs
The sanding discs are behind and they just stick to the top of the pin which is locked into place by two grub screws and a Allen key, this is stored on the rear of the drill.
Very impressive, I tend to sand far too hard ( no doubt from working on trucks) and more than often destroy everything in my path lol. The discs are 5mm so you can sand a small area very well. Sanding the line quickly, in two steps then finished with a very fine sanding pad. Line gone.
