That is soooooo nice! Well done, you should be proud of it, I certainly would be!
Compared to the finish that I get with the airbrush, my hairy stick effort came up wanting, although I'm sure that with more practice I would get better. :smiling2:Hi Garry, sorry, I actually meant what was it about the brushed paint finish that you weren't happy with - but thanks muchly for the notes on the fit, I'll keep that filed away for when I build one.
Thank you Steve, I appreciate that.That is soooooo nice! Well done, you should be proud of it, I certainly would be!
Thank you sop much for your kind comments.Garry that is one Beautiful Big Bird. Great finish on the build and the Camo. Oh and Congratulations winning the “Dogs” award. I’ve been looking at these Airfix bombers for a couple months now I’m thinking of getting one but a little nervous about the build.
I'm to stupid to realise what I can't do
I don’t think it was Stupidity maybe being overwhelmed and intimidated. Don’t put yourself down like that your too talented modeler for that.
Very kind of you Lee, many thanks.Lovely result Garry
Got it.tongue in cheek, hence the wink emoji
Got it.
Many thanks Steve.Lovely job - despite your misgivings!
Thanks Mike, I appreciate that.Really good. Great paint job.
Thank you so much Andrew, that means a lot coming from you.Garry
That's very nicely done indeed! No complaints from me at all! I the non-dambuster version in the stash too, so nice to see what it can turn out like!
ATB
Wow Ron, I can only imagine that Airfix have different moulds for the various versions then, as mine was not that bad. Of course you will tame the beast, it goes without saying.Excellent result Garry. :thumb2:
Regarding the Airfix Lancaster (Ordinary Version) anyone contemplating purchasing the kit had better be ready for a fight!
The one I'm building at the minute is a pig to build. I will complete it, but it is no pleasure to put together. Over engineered, very fiddly and messy......
The choice is with the modeller, but if you want to sleep at night, I would seriously suggest leaning towards the Revell offering. ( I have built it)
Very good advice Arnold, thank you.Well if that's your starting point then I'm sure you could - it looks great. There are things that can help with brush painting, thinning the paint as you would an airbrush, using matt paint (never brush satin or gloss paints if you can help it), using decent water based acrylics (I'd avoid the likes of Tamiya) and a wet palette. Using a good quality spray primer and clear coats.
There's also this thing about 'using the widest flat brush possible' and moving it in the direction of the airflow etc. etc. It works for some people to be sure - but I tend to use a smaller no 4 round tip brush, small amounts of paint at a time, and work it around to remove build ups.
I stick to Vallejo paints so that I can "master" one brand, as to brushes, fortunately I have a very good selection.
I think my mistake was attempting to freehand the camouflage, it would have been better to mask I reckon.
