Tim’s 20mm SHQ miniatures Airborne Vickers mg team
I was like Jim - I could hardly make them out in the metal, but the primer and wash have done wonders.
Do you hold the golf tees while painting, or support them in something? I have to attach small things to something heavy or they just shake around. It's like trying to paint a moving target :tears-of-joy:
I haven't quite got the hang of locking my hands together like my lad does.
Hi Andy. Yes, I do hold the golf tees. I used to blue tack the figure to the tee, but then had a brainwave. As I use coins as bases, which are magnetic, I glued magnets to the tees. The neodymium magnets hold the figures tightly enough to be painted. I have to pick coins that are steel though, the older copper based ones aren’t magnetic. Locking one hand over the other is a skill worth learning as well. It doesn’t stop the shaking, but both hands shake together so it minimises the problem. I know what you mean about weight helping. When I had a very light SLR camera I had the same problem. A heavier camera means less camera shake, at least for me.
Actually the first time I’ve used black washing for a couple of years. On the brighter fantasy stuff I prefer Zenitel priming these days. Hope I don’t disappoint…..
I have EVERY confidence in your abilities Tim.... No pressure at all!!;)
Thanks Tim. I recently ordered a load of small magnets for something else so will give that idea a try.
Of course, it only works if they are gaming pieces and you mount them on coins as I do Andy…..but I’m sure you worked that bit out :upside:
Well, some progress on the little chaps at last….not the best picture, sorry…..
Faces, hats, boots, and trousers done now……currently working up the denison smocks. Base layer painted and highlighted (and all the work blown out by the camera….), so brown and green splodges next……I don’t try to follow the pattern when I do this, at 20mm I think it would generate lunacy…..
Brilliant and informative Tim ,can't believe the detail the wash brought out ,ive some metal Perry bros Sudan figures that I bought when I thought I'd become a figure painter along with wet pallet paints etc still living in the cupboard not touched keep this up I might have to show em the light of day. Dave
Cheers David. The Perry Sudan figures are very nice, I have some myself. If they are the plastics then I painted some a few years back. They can be found here…..
https://www.scale-models.co.uk/threads/british-infantry-sudan.30521/
…and here….
https://www.scale-models.co.uk/threads/ansars-on-a-postcard.30098/
I did do a heliograph team but I can’t seem to find it……
Plodding on with these guys…..just need bases painted, varnish, shiny highlights, and basing now. I’m doing the Vickers next…..
….and here is a very cruel close up…
I’m glad the four gallon Tamiya bottles are still available……they would look impossibly small otherwise…..
