Neil's Italeri 1/35 LCVP Landing Craft
As an interesting aside , with regard to research, I was trying to discover what colour to paint those life rings, and almost all colour photos around are of modern restorations and the life rings are orange, presumably because of current safety regulations. I was sure this was not correct for the period, but it took me quite a bit of trawling to figure out that they were mostly white at the time. Some were dark grey, but I wanted the contrast
Good move changing out the ropes, much better. The rope colors are really good too, they give good contrast to the grey tones of the boat. Excellent progress, Neil!
P.S. Bright orange or red rings would be like, WOW, easy target, HA!
So many wonderful, well considered details. Life belts look spot on painted up. Replacing the life ring ropes was a good move.
Well I was supposed to make an inflated life belt, but I got distracted.
I have always intended to have a bucket kicking around (see what I did there ;) ..) somewhere, as shown here
I have an old Tamiya one in the spares box, but it’s a bit knackered, and not in a good way,
and if I cleaned it up it would be too pristine, so I planned to 3D print one. But, as I say, I want it to be dented but I don’t know how to make that effect in the digital model I have; and denting rarely looks that convincing doing it to resin or plastic anyway. So remembering the front bump on the bow door, and inspired by @scottie3158 and @Scratchbuilder I decided to make one out of metal.
I used the Tamiya bucket to make a template from paper
I just impressed the shape with my fingernail into the paper and opened it out
Then I could cut it out with scissors
The pencil line is the join line. I then cut the shape from thin metal sheet-in this case it’s a tomato puree tube.
I put double-sided tape on the bucket to keep the metal in place while I trimmed the metal more precisely
I used my fingernail again to indent the metal into the detail of the rim and the base
Next I removed the metal by flooding it with lighter fuel to release the glue of the double-sided tape
And superglued the edges together. Using fine pliers I gradually bent the rim over in stages until it was folded flat.
For the base of the bucket I used leather punches to make a 7mm styrene disc and an 8mm metal disc, and I carefully folded the 0.5mm extra metal all round over the edge of the styrene disc.
And then ca’d it into place
Now I added the dents I want and the finally a handle from wire
It’s a shame one side of the metal is gold colour or I might leave it unpainted, but it would look a bit odd.
So sorry chaps , you’ll have to wait a bit longer for my cunning plan for the inflated life belt.
Thanks for looking in
N
There's no limit to this guy's ingenuity. He's made the bucket , now onto the spade.
WOW Neil i never knew there was so much work to make a tiny bucket but wow im impressed that you sir made the attempt an very well done
chrisb
Superb stuff Neil. Masterclass is the word that comes to mind :thumb2:
Brilliant. So much effort and detail on this model.
Neil, just caught up on your build, but the best part has got to be the bucket build. As you say - drooling.....
Bucket SBS put away for future reference.
......ah yes...drool buckets...us older gents recall them.
Neil,
that is outstanding mate.
Great SBS on bucket building.
Great detailing Neil
chrisb
Bingo, that works!
Wow !
well that was unexpected ,thanks very much Gents, how very gratifying.
Right then, let’s do it!
Having solved the problem of the uninflated life belt I now want at least one inflated one and, as I said, I have been mulling this over for a fair few years.
Here is my eventual solution - it’s an experiment because I haven’t got round to testing my theory until now...
Heat-shrink tubing, used to insulate electrical connections. This is the smallest I could get- 1.6mm- but I think it will work.
I want to shrink the ends down to fit over my 3D-printed nozzle, which is about 0.6mm diameter, but I need to control the amount of shrinkage so I found a piece of metal tube 1.6mm diameter, and inserted a pin in the end
This stops the whole tube from shrinking.
I was relieved to find the tube still slid out...
I made two of them and trimmed the thinner bits
I stuck the two ends together with ca and left them to set, to be absolutely sure
Then I glued the rest of the tubes together and stuck the nozzle in
I then added the other details as before, from lead foil and solder
And painted it
Works for me.
Phew!
I didn’t have a plan B so I am quite chuffed. I’m particularly pleased with the way the black tubes go into the main body, it has behaved just like the real thing.
Thanks everyone for following, the end is in sight!
Cheers Neil
Honestly Neil that is so, so clever and so effective. Well done.
With your inventiveness you should move away from modelling, invent something useful, you'll be rich in no time ;)
