- Joined
- Apr 27, 2018
- Messages
- 14,948
Joe, mighty fine figure work there mate.
Thanks Richard…the figures were actually painted with a moist brushing ( if there is such a technique????) …more so than a dry brushing, but you are right, there were still flaws in the blending that were noticeable and they looked dry brushed…so I went back and did more of a diluted, translucent type of highlight as you suggested and I can see the differences…they may appear more subtle in the pics but I can definitely see the change. The hardest ones to create the effect on are the tamiya figures that lack the detail of the other resin and dragon figures. thanks again for the help..Don't knock yourself down so hard Joe, your figures are good. Painting these many for a diorama isn't easy unless you have pre planned positions in the composition for where the main light source comes from in your head. This helps hold the composition together in the final stages.
On close up I noticed you're using the drybrush technique...I had problems with paint build up in the past when I laid it down too thick and wanted quick results. I learnt that thinning paint to near translucent and layering patiently with a sharp pointed soft brush produced smooth results. I usually spend a day or more on each figure sometimes treating each colour or effect like sub assemblies. With practise it has worked for me.
The photos haven't done justice to the figures as most are back lighted and in hight contrast. I bet they look even better with the naked eye. Can't wait to see them in the finished Dio with the excellent vehicles.
Wabble
