1/32 Revell BAE Red Arrows Hawk
HAWKERHUNTER
Hi. Hope you are all well at this difficult time. Just started work on my 1/32 Red Arrow Hawk. My last 3 offerings were in 1/72 scale so its really great to be back working on a larger scale kit. At least I can see the parts. So first impressions of this kit. Think I paid under £20 for this kit which I dont think is a bad price for a large model. Kit contains 155 parts which are moulded using red plastic which seems a little strange to work with at first but you soon get used to it. The parts are fairly detailed but do seem a little thin. One of the wing halves had quite a nasty warp in it but it shouldn't be a problem to sort out. Some really nice design work by Revell on the air intake and exhaust pipe work which all fits together really well inside the fuselage. Instructions are clear and the decals seem up to Revells usual high standard. Only thing I wont be using are the stock kit ejector seats and decal printed seat harnesses. As this aircraft has a large cockpit area on view I have ordered 2 Martin Baker Mk10 Quickboost resin ejector seats which are far more detailed than the ones provided in the kit. I will probably be looking for some guidance from the painting experts among you in order to get that pristine Red Arrow gloss finish, something that I have never tried on a model before. So here are a few of the sprue shots but as you can see work has already started.
Very nice. I wouldn't mind one of these myself one day. A word of warning with a gloss finish, sometimes it can be a bit to much in a scale model. It's just my opinion, but often, a satin finish can look better.
Nice start to it Steve, i'll be following along on this..(if i can squeeze a chair in amongst the regulars), i've got the 'black' re-box of this in the stash, so i'll be watching your every post carefully in the hope it will stir up the need to break mine out...
Thanks for logging in everyone. I get what your saying Colin. Ive always used a satin finish in the past but was hoping to get that polished look. I will be spraying up a spare wing from a previous build to practice on but if all else fails it will get the satin finish.
Morning all. So just bringing you up to speed on my Red Arrow Hawk progress
Photo 1 and 2... I noticed that when joining the two halves together there were a couple of areas where I had to apply a little more pressure than I would have liked to close the gap. Ive never been one for gluing and clamping just in case the seam comes apart later in the build, usually after its all painted so I spent some time filing down some internal parts just to take the pressure off the join. Reasonably happy with the fit now but just to be on the safe side I have added some plastic card reinforcement on two areas of the seam that I know will need a bit of filler. These will ensure a strong bond which I find really helps on these larger builds. The fuzz halves are now ready to join up.
Photo 3 I have removed all the control dial impressions and flattened the control panel surfaces. They have now been primed, painted, glossed and the control panel decals added. I have always had a lot of luck with Revell decals and I think they have done a good job with these. Happy with the result.
Photo 4,5 and 6. The Quickboost Ejection seats have arrived. Early indications are that will fit perfectly once they have been prepped. Massive improvement on the stock kit ones and lots of fine detail to work with.
Photo 7. This is what I need to try and replicate when I paint the resin seats up.
Main work today will be finishing some detail in the cockpit, making up the wings so I can test fit into the fuzz and then joining the fuzz halves together. Will need to do that in stages.
Morning All. Progress to date.
Picture 1. The two fuzz sides have been joined. No major dramas there. I did it in stages using a combination of epoxy and standard plastic glue. Some work to do on the seams but nothing major.
Picture 2. The undercarriage bay internals were fitted and the wings joined.
Picture 3. After doing some preliminary filing of the seams on the fuzz the wings and fuzz were joined. Slight bit of filing needed on the wings to get a good fit into the fuzz.
Picture 4. Slight ridge where front of the wings join fuzz. First bit of a bad fit that I have come across so far with this kit. No way to avoid this ridge without causing misalignment in other areas of the wing fit so it will just have to be sorted with some filler.
So apart from that now begins the slow process of flatting the seams and some re scribing where required.
Morning All. Before I bring you up to speed on progress just wanted to mention a couple of building points for anyone planning on building one of these that may save some heart ache in your build. Please don't think I'm trying to teach anyone to suck eggs its just that I do suffer from go fever sometimes and go charging in making stupid mistakes and I just want to give you the heads up to avoid anyone making the same.
Photo 1 and 2 show the plans where you are asked to fit several small round clear parts into the fuselage. These could cause more trouble than their worth when it comes to masking them off for painting of the fuzz later so I have left mine out. I intend to make them up using Micro Kristal Klear after the fuzz is painted and varnished.
Photo 2 and 3. Again the plans would have you install 6 under wing hard points early in the build. However one look at the decals clearly show that if fitted these will interfere with the decals that go on the underside of the wing. So to make the decal process less problematic I have left these off and will fix them after the decals have been applied.
Also because the tail plane of the Hawk is all moving and doesn't need any filling where it joins the fuzz these can be added at the conclusion of the build and make handling of the model easier during the finishing process. Another thing that I am pondering over is when to add the ailerons and rudder. The hinges for these are very fragile and I just know in my clumsy hands they will get broken if fitted too soon .
The final 4 pictures show the model after some filling, sanding and the first coat of Humbrol primer. Fairly pleased with the result and think I have managed to sort the seams out on the first attempt. Bit of re scribing to complete then it will be time to think about the distinctive top coat of red.
Have a great day everyone.
As my mojo is in overdrive and before I start any more new builds I have made myself dig out two half completed builds. The first one is this BAE 1/32 Hawk. For the life of me I dont know why I stalled with this one as its a gorgeous kit and wasn't causing me any problems. So here we go, second attempt at completion.
You can see that the model is in a filthy state having been home to various garage creatures like Spiders etc. So today I will be cleaning it up, going through the plans and cracking on where I left off. The interesting part for me will be getting that super Red gloss finish that we associate with the red arrows and also tackling the super detailed resin ejector seats. I haven't got a clue where to start with painting those but here goes.
Now when you said you had dug this one up again I didn't think you ment literally. lol.
A nice looking birk the Hawk and look great in a nice glossy paint job. Mine's black.
No. Wasn't joking Ian. Been sat in my stash cabinete at the back of the garage, (which is my man shed where all the modeling goes on), for 4 years. First job was washing the thing down and refreshing my memory as to where I had got too. progress has been made and it is now clean and No1 on the runway/workbench.
Nothing ruins the aesthetic of a well presented model like spider pooh!! Ha!
Always good to see a stalled project resurrected
Miko (sadly no space for 1/32)
I will soon be resuming work on this one. I am determined to get it done before Christmas. I realise now that the reason I stalled on the build of this model is because of the highley detailed resin ejector seats. I look at them and have no clear idea of a painting sequence for getiing them painted. Do I start with the belts then move onto the seat padding or vice versa. You can see from the photos they are highly detailed particularly on the bottom seat cushion area which is littered with a mass of belts. So can I ask anyone who has tackled one of these to please let me know how you would go about painting them I realise that many of you may tackle them differently but I am keen to hear all your methods. Thanks guys. If I can make a good job of these then this baby might get finished.
Considering how famous the Red Arrows are we see few builds of their Hawks. That seat is superbly detailed. Now the spiders have been evicted I look forward to the completion of the build.
Nice, looking forward to see this one finished 👍
I like to start with the largest-surface-colors, so the cushion first, the metal side-panels, then all things which are 'on' it, like belts etc... have fun!
So progress has been made on the Hawk after it has been sat on the shelf of doom for 4 years+. Firstly it had developed a crack along the seam on the spine. Not sure how this has happened because earlier in the build and recorded on this thread I has concerns about the joins on the two fuzz halves and took what I thought were reasonable reinforcing steps to prevent cracks happening. Anyway in its four years of being stashed away it has cracked so that needed repairing. Following filling and prepping I coated the model in a white primer ready for paint. I intentionally left the white primer patchy in places.
Click image for larger version  Name:	IMGP0041.jpg Views:	1 Size:	203.4 KB ID:	1240394
Next was the application of first coat of Revell Gloss Red
Click image for larger version  Name:	IMGP0043.jpg Views:	1 Size:	360.3 KB ID:	1240395
I havent done any substantial preshading on this one other than the patchy primer. I just thought they are so pristine that some panel line wash will be all it needs. Time will tell. I have also been working on the two Martin Baker Mk10 resin ejector seats. I am about 50% through and I have to say they have not been the beast that I thought they would be. Still got a lot of shading and dry brushing to do together with picking out the finer detail on the sides but all in all I am pretty pleased with how they are coming along.
Click image for larger version  Name:	IMGP0045.jpg Views:	1 Size:	230.8 KB ID:	1240396
Click image for larger version  Name:	IMGP0051.jpg Views:	1 Size:	258.8 KB ID:	1240397
Thanks for tuning in.
