1/48 Hachette U96 Part 1
Shaping up nicely. Soooooooo much work. PaulE
:flushed::tongue-out3::blow-kiss::smiling2:...Crazy work man...
View attachment 417573View attachment 4175741/48 Hachette U96 Part 9
Sanding time not much to say other then hours of sanding with course medium and fine until the model is smooth and ready for priming done outdoors with a dust mask as per safety guidelines
Hi Colin
Great job. Odd that there are plastic and planked areas. I can imagine the hours of work needed to get a decent finish.
1/48 Hachette U96 Part 12
Start of the decking details and 1st parts of the 8.8cm Deck Gun basically just a case of sticking thin strips into place on the various bits of the decking before lightly sanding them smooth then painting them
Regards
ColinView attachment 420413View attachment 420414View attachment 420415View attachment 420416View attachment 420417View attachment 420418View attachment 420419View attachment 420420View attachment 420421View attachment 420422View attachment 420423View attachment 420424View attachment 420425
1/48 Hachette U96 Part 13
Ok so here we go with some traditional model building 1st off I finished the 2 guns namely the 8.8cm Deck gun and the machine gun loads of brass pe I hate pe sometimes I think they do just for the sake of it anyway the pictures should show more than the words can tell so here goes
After the pe was glued on with much teeth knashing and swearing etc it was time to paint them basically 2 colours light grey along with dark grey in certain areas they do look quite good even though I do say so myself next we start the bulkhead walls
Regards
Colin
View attachment 421295View attachment 421296View attachment 421297View attachment 421298View attachment 421299View attachment 421300View attachment 421301View attachment 421302View attachment 421303View attachment 421304View attachment 421305View attachment 421306View attachment 421307View attachment 421308View attachment 421309View attachment 421310View attachment 421311View attachment 421314View attachment 421314
1/48 Hachette U96 Part 14
Bulkhead assembly so 1st off paint the bulkhead 2 tone upper half white bottom half light grey next you have to drill out all the pin fixing holes for the various control wheels etc which are mounted via the pin through their centres the wheels are painted red on the 1 st Bulkhead and various colours on the 2nd Bulkhead next paint the various bits of pe the required colours before attaching them to the bulkheads some pieces are tiny as can be seen from the picture with the tweezers and my finger basically you just work your way through the instructions adding one piece at a time all the circular gauges indicator dials and handles are all brass pe after all this was attached a considerable amount of touching up was needed to make the bulkheads look presentable
I also added some details to the conning tower at this stage which looks very rough and ready at present but should clean up afterwards also a brass side panel of some sort was also constructed and then painted dark grey don’t know what this does yet as the instructions say save it for later
Regards
Colin
View attachment 421319View attachment 421320View attachment 421321View attachment 421322View attachment 421323View attachment 421324View attachment 421325View attachment 421326View attachment 421327View attachment 421328
1/48 Hachette U96 Part 15
Just a small update to the build which is getting very intricate with loads of tiny parts and detailed painting with the net result we have loads of separate sub no pun intended sub assemblies which I’ve no idea where they go yet
Regards
ColinView attachment 421912View attachment 421913View attachment 421914View attachment 421915View attachment 421916View attachment 421917View attachment 421918View attachment 421919View attachment 421920View attachment 421921View attachment 421922
1/48 Hachette U96 Part 16
More interior details being done this time the main engines and associated pipe work and valve control gear including tiny rocker type push and con rods requiring tiny holes to be drilled into the mounting surfaces this is really testing my skills and unsteady hands to the limit at times
As you can see some more tiny pieces which worries me as to the longevity of super glue and these pieces staying attached using this adhesive to stick brass together and onto other materials
Next the engines get painted and detailed along with more interior details
Regards
ColinView attachment 423676View attachment 423677View attachment 423678View attachment 423679View attachment 423680View attachment 423681View attachment 423682View attachment 423683View attachment 423684View attachment 423685View attachment 423686View attachment 423687View attachment 423688View attachment 423689View attachment 423690View attachment 423691View attachment 423692View attachment 423693View attachment 423694View attachment 423695
1/48 Hachette U96 Part 17
Painting engines and adding more details and general overview of parts built so far
The engines are also painted white overall with the push rods painted black and the main handwheels painted green with the small handwheels painted red
The main valve assembly which is what I call it is grey with black control valves each of them having a pin mounted through their centre which will need shortening to 4mm long before gluing them into their respective holes there are 6 of them in the centre and 2 on the outside also a large brass work structure has also been built purpose at present unknown you are now up to date with where I have go to with this kit
Regards
ColinView attachment 423696View attachment 423697View attachment 423698View attachment 423699View attachment 423700View attachment 423701View attachment 423702View attachment 423703View attachment 423704View attachment 423705View attachment 423706View attachment 423707View attachment 423708View attachment 423709View attachment 423710View attachment 423715View attachment 423714View attachment 423713View attachment 423712View attachment 423711View attachment 423710
1/48 Hachette U96 Part 18
Ok so now move onto more interior details and the start of the periscopes and railings for the conning tower
1st off is another internal bulkhead with numerous bits of pe attached and then painted white then comes a large brass type fixture which I have no idea what it does or goes then we start with another bulkhead adding a copper pipe to one side of it then we come to what I call a valve distribution tree to which most of those tiny valve handles with the pin mounted in the centre go having been painted black
The 2 finished bulkheads are then painted white with additional parts painted various colours as seen in the attached photo
The valve tree is fitted onto the bottom of the bulkhead next the start of the periscopes assembly where you have drill out the holes for the handles and fittings then the periscopes were painted along with something that looks like life belts painted red and grey
Next is the biggest problem of all handrail attachment to the conning tower this took 2 days of fettling and finally I gave up with gluing the 2 separate sections together on the left hand side as it kept breaking apart when being shaped to fit toView attachment 424602View attachment 424603View attachment 424604View attachment 424605View attachment 424606View attachment 424607View attachment 424608View attachment 424609View attachment 424610View attachment 424611View attachment 424612View attachment 424613View attachment 424614View attachment 424615View attachment 424616View attachment 424617View attachment 424618View attachment 424619View attachment 424620 the holes I drilled into the conning tower so my solution I secured the joints using paper flower petal wire this is ultra thin wire about the thickness of cotton thread so I wrapped the 2 joins with this and the secured the ends with super glue not perfect but better than it constantly breaking
1/48 Hachette U96 Part 19
We now come to the marking out for all the external brass work to be added to the port side hull and I finished off the conning tower giving it the final colour it appears in as well as adding extra detail like the red & green navigation lights still got to add the glass covers probably make them from clear sprue cut directly in half make cover for each that way they should match
So after a week of nights I finally have the port side fully brassed strip finished now move onto the starboard which as this includes cutaways should be very different from the full length side
It would appear my photos have come backwards meaning the 1st one should have been the last that way they would have matched by text oh well never mind you should be able to get the gist of it and the tardy appearance of the model will disappear once it’s all painted hiding all those marks etc
Regards
Colin View attachment 425423View attachment 425422View attachment 425421View attachment 425420View attachment 425419View attachment 425418View attachment 425417View attachment 425416View attachment 425415View attachment 425414View attachment 425413View attachment 425412View attachment 425411View attachment 425410View attachment 425409View attachment 425408View attachment 425407View attachment 425406
