Blimey thanks Ian!I’d be completely over the moon if I had half the skills you have. Fantastic work, loving watching this build Neil.
:smiling5:Neil,
Excellent work mate the hand looks great did you roll little sausages for individual fingers or did you form them from one block?
You're absolutely right, Rick, but for this exercise I was simply following the scribed lines on the model kilt, just to see if I could even do it! The lines are actually wrong in that thy fan out from the waist at the front, when they should be absolutely straight.the kilt only gets its shape from the pleating around the sides and back, which is going to be a considerable challenge, and mine has a great big fold in his lap, front and centre, which I will need to get spot on.I would try to follow the contours and folds in the kilt a bit more as I think it might look a bit more natural....it just appears a little stiff to my but I'm no expert.....not even a novice for that matter. Rick H.
Cheers Steve, you certainly do.A brilliant first attempt Neil. You certainly need to have a steady hand for this sort of work
