A pair of resin figures approximately 90mm picked up from a particular Chinese market place.
I realise that these are probably recasts and I would have preferred to buy from the original source but I've not been able to identify the original producer online.
The first I have finished in 1990's era desert DPM with a mix of gear including both early and late 58 pattern webbing and a non-descript Bergan.
The barrel of the SLR was broken on arrival and I had to drill out the fore-stock and flash hider to insert a bit of carbon fibre rod so it is a bit skew and I've just noticed it is upside down ( the bayonet lugs should be at the bottom)!!
As he is toting an SLR I did wonder if it was actually meant to represent someone a bit earlier and could be in jungle DPM however the 66 LAW wouldn't fit with jungle.
The second is obviously Gulf War 2 or later ( mid 2000's to present day ) as he has an SA80 and appears to be wearing full MTP including the load carrying vest.
The casting quality of the second guy leaves a lot to be desired especially around the face. The stubby barrel of the SA80 is slightly warped but it is too short to realign.
