Back when I still used them, I had no trouble painting Tamiya tracks with acrylic paints. Fitting them is also very easy: remove the idler wheel from the model (it’s Tamiya, so they’re held on by poly caps), hook the track over the sprocket, then put the idler into the track and use it to pull the track so you can pop the idler back onto the model.the thing with these rubber band tracks. You can't glue them, you can't paint them and they are tough to fit.
