Airborne's Dragon 1/35 150mm Howitzer
Airborne01
Tempus Fugit, not helped by a considerable amount of time at school away from the bench, but I've managed to get some sub-assemblies for the howitzer done! Haven't posted sprue shots as they were included in the original post. I'm fairly sure I shall get this whole build completed on time :cool: As highlighted in previous posts there are lots of errors in the instructions; transposition of part numbers, vague location pointers, missing part numbers etc. I've added hydraulic brake lines although I make no claim as to accuracy of location etc - they look ok to me though! However the parts fit with typical Dragon accuracy once cleaned up and are full of fine detail, some too fine for geriatric chipolata fingers and fading eyesight! As an aside, the Carpet Monster hasn't coughed up the grab rail, and the decals for the prime mover dashboard is lost in the limbo of the Postal System :angry: Anyway, on with the motley and here is progress so far ...
Nice paint work, what are you using Steve ?
Thanks John,
The paint is standard Humbrol 94 with blends of H83 and Khaki to provide tonal variations; Vallejo acrylics washed very thin to grubby it up! I use heavily thinned Track primer and/or Dark Rubber for grime and the tyres are Dark Rubber base with a 50/50 mix of Dark and Light Rubber for the running surfaces! And sometimes I have the occasional brain f--t and think 'That'll work ... !
Nice paintwork. Will there be camouflage?
Not this time Ian, due to time constraints, but I have a cunning plan for a future build! I was watching a documentary on Das Reich moving up through the Ardennes last night and it was apparent that the majority of prime movers and Arty weren't cammed, which surprised me :thinking:
Yeah,gotta agree with the guys....
..... That paintwork is excellent Steve :). Lovely wear on the contact surfaces,not too much.... just right ;)
Looking forward to seeing it come together.... A shame no camo,maybe next time eh?!! ;)
Thanks John,
Thanks, it has a realness to it .
Sorry, no cam! However this is almost complete (For the purposes of the current thread it is ...) and will shortly re-emerge under the guise of 'Dioramas under Construction'
Looks a beauty. Don't forget the rocks in the rock cage to stabilize the tow bogie.
Not sure I know what you mean Paul; was there usually a 'rock cage' or counterweight attached over the tow bar/ front bogie to keep the whole muzzle-heavy piece balanced when under tow? If so that might explain the purpose of the upright fittings on the front bogie!
There is a shelf of expanded metal underneath the bogie's axle where rocks could be placed to add extra weight. Maybe this was if they didn't have time to take the barrel completely out of battery for travel? Don't know, just seen it in photos and guessed, as some pics show travel in battery.
Don't know for sure either Paul, but it sounds like an interesting and feasible plan! I think the perforated plates are to counteract soft ground similar to the wicker but both usages sound plausible - if there are cognoscenti who have a definitive answer I swear I shall be 'eternally' grateful! (Well, not that long!)
