Airfix 1/72 Hawker Hurricane Mk.1
Decals are now all on, mercifully a relatively quick job after recent builds.
Very nice indeed. And I'm even more tempted to do a third (or fourth?) one of these now
Does the gas warning panel really sit that far out on the wing, as they're usually positioned closer to the cockpit? It might even be easier to see there out by the roundel
That's turned out a real treat.
That masking putty - do you find it tends to sag, sort of flow off, so you have to paint pretty soon after applying it? I don't know what make yours is but mine does :)
Another cracker Joe. Lovely finish on a true classic of the skies.
Cheers Steve, nearly there, I will post the completed pictures soon
Thank you Chris
Cheers Jim. The putty I have is AK, but all of the generic brands are the same. I left the Hurricane putty on overnight after applying. The trick is to not use too much, spread it with a finger so you have a thin mask, rather than using blobs. It self-levels, and as you suggest, using too much causes it to 'flow' due to gravity. A little goes along way.
Chris, this photo is from the IWM. I'm not sure there was a definite position for gas patches, but this one is clearly on the outboard of the roundel.
And that's the picture Airfix based this kit version on, I see. Nice to see some proper research being done
On the photo, does it say where it was taken? That's a lot of very flat open space there!
