Airfix 1/72 Ju 88
Well Paul, interesting is one way of putting it
Hard to believe that is the same kit Steve, very nice and clean work as usual from you. Look forward to seeing the framing. When I did the Revell Hurricanes I used painted decal strips. Not seen tape used, but it might be easier to apply than the decal strips.
I've made a start with painted tape and it looks like it'll be a goer.
Interesting you ended up there Steve. That is exactly how I used to do canopies as a youngster, with probably the same kind of standard of plastic you are dealing with now.
It looks okay Richard. At this scale it might be a little over scale as there's a limit to how thin I can cut it and still have it stick to the canopy (I've been experimenting!). I've made an intentional decision, having looked at drawings of the original framing, to do an impression of the framing which should look okay rather than literally replicating every element. On the grounds that the little bit I did worked I've got more painted tape drying for tomorrow. Last chance to finish this tomorrow as I fly to Vancouver on Monday and won't be home until November!
I'm calling this done as I've run out of time anyway!
I've not done a proper photo job, just selected a few snapshots that aren't to blurred with a suitably Norwegian looking background :)
It's a horrible old kit but quite fun to knock into shape. If I was trying to make a serious 1/72 scale model of a Ju 88 this would not be the starting point I'd choose!
You've certainly beat the old bear into shape steve, nice work and it looks great.
scott
Lovely job.
Would really like to hear a bit more about the canopy framing you did, have a similar beastie in the queue and was thinking I might try the same thing.
Looks a really neat job Steve from very humble plastic. Might be worth giving a little 'how to...' on the canopy framing. I know that 1/72 really isn't your scale but I think it would be of interest to the 'Braille scale' modellers and I'm sure they'd appreciate having another technique in the locker.
I love the backgrounds too. Do you print these off on your own printer?
One last thing, what's up next? Back to 1/32?
Again, great job
P
Cheers fellas.
For the framing I just cut some thin strips of Tamiya tape, stuck it on some tin foil and painted it RLM 70 and RLM 65. Once dry I could liberate lengths, clean up the edges, and apply them to the canopy. I did look at the framing on the full size version and decided not to replicate it exactly. Discretion got the better part of valour! If you make the strips too thin they won't stick which means the framing is inevitably slightly over scale, but the strips give a reasonable impression and are a lot easier than the alternatives.
The trickiest bit is cleaning up the edges of the strips when you lift them from the foil. I had to put them back on a cutting mat and run a very sharp blade along the edges to remove excess paint and tidy them up. You're going to need a new scalpel blade to cut the strips anyway.
Next up, when I get home, will be a 1/32 Bf 110.
Wow Steve, you surely made a "difficult" model into a very nice looking one :-)
Theuns
Im sure you will come out on Top with the build Steve, Looking good so far... :)
John.
