Andrew's 1/48 Tamiya Panther D
adt70hk
Hi all
Ok, so slightly late to the party but here in the end.
Firstly, thanks to Paul for suggesting it. I can see there has been a lot of work started already, so I'll have to have look when I have a minute
I spotted the GB idea a week or two ago and happened to have this sitting on the table (as there was simply no room anywhere in the stash storage!! 😟)
And, yesterday, the model group I run at the church I attend, had an all day build day - so now the P40B is nearly done, I thought it would be the perfect candidate for the day. Planes are tricky because of the need to paint the cockpit before assembling the outside and major painting on the day is not possible. We started at 9 and finished about 4:30, so I got plenty done - as you will see below.
This is one of those kits that has a metal hull for some reason - not sure why they did it but it does give it a nice weight.
I have to say that so far the fit has been flawless.....absolutely flawless.....with a lot of good crisp detail - so if you fancy some mid-sized armour then you can't go wrong on this.
Obligatory sprue/destruction and progress shots below....as you'll see I made a lot of progress....for once!! 😉😂🤣
ACW as usual.
ATB
** this is the kit I won in the tombola last month, so only cost me £2.50.....😁😁😁😁
To attach the top, you get in place to slide it along the bottom from the back, engaging the clip in the attachment point.....
Is the croissant to scale? Looks a little large :ROFLMAO:
The paint scheme looks interesting
Good choice for this GB. Not seen a kit with a metal hull before. I wonder why?
Interesting choice Andrew 👍
It looks a nice scale if you’re limited for display space.
The paint scheme looks like it will be “fun”😳
Geoff.
