Another polishing question.....
PaulTRose
Tattoine
Paul
Tattooine
....... Cos i really dont know
Ive never been one for polishing cos ive been happy with how things have turned out but i want to try it.... So i bought some tamiya fine compound and some lint free cloths......... But what the order of things?
Do i polish the paint to get it smooth then clear coat.... Then polish again?.......... Or clear coat and polish just once??..... Or what?
Muchos gracias for any help provided
There's no need to polish the paint if you are going to clearcoat over it.
As long as it is pretty smooth that's fine, it doesn't need to be particularly shiny as your clear will do that job for you, then polish that once fully cured.
Good question Paul, I was pondering something similar myself.
I saw a YouTuber earlier saying how he polished a primer coat before adding top coats 🤔.
I’ve never done that before, does anyone else here do it, have I been missing a trick 🤷‍♂️.
Geoff.
Geoff.
I wouldn't mind seeing the video to hear his reasoning behind it but to me it's completely unnecessary, and even detrimental.
The main role of a primer is to promote adhesion between the substrate and the following coatings. The waters get muddied with primer surfacers or primer fillers as they also hide imperfections, but they are still helping adhesion.
By polishing their surface you are making them smooth at a micro level, giving the following coatings less surface area to grab onto for mechanical adhesion.
Sure, if you are using a solvent/lacquer primer followed by the same kind of paint, there will be chemical adhesion where the solvent reactivates the primers surface, allowing some migration between the layers (think about how solvent cements like TET etc work by dissolving the plastic on both parts a little to enable them to bond together), but not everyone uses lacquer products.
Even in cases like that though, some mechanical adhesion will likely provide a better bond, so smooth, but not shiny ("smooth" on a much finer level) is generally thought preferable.
I am no expert on this subject but from my own experience I have to agree with the advice Andy has given. I have just used these polishing compounds for the first time. I applied several coats of varnish onto a paint coat that wasnt perfect. When fully cured the varnish buffed up as smooth as glass. Just remember my bad experience with the dremel pad that I posted recently and buff up by hand only.
Andy did this for a living, so his advice is gold standard. I would follow that, only adding that allowing the paint to gas off properly and harden right through the layer is also necessary to get the best results. The only time I would polish between layers is if my spraying has been sub par and I have minor orange peeling to smooth out.
If you want to see how effective these compounds are, and to practice with them a bit, use some left over clear parts. You will see them turn from plastic to glass before your eyes.
Another tip is that if you are building something like a motorcycle that has a black vinyl saddle cover, then polishing the black plastic part can give it that vinyl appearance without using paint.
Thanks Tim, and I still do. No rest for the wicked 😂
This Jap import love bus is a perfect example. It's a factory paint job but you can see how shiny the primer is, so the paint has just peeled away in big sheets from the roof, one wing & tailgate, only sticking in certain places where some debris must have been sanded out of the primer.
Can't wait to fix it 😩
Cheers Andy, that makes sense 👍.
He didn’t really give a reason he was talking about a new primer he had used which he said polished really smooth. I didn’t think this was a necessary step hence my question.
Geoff.
Ok oh wise gurus of the polishing cloth..... Next question
How do you get rid of any excess polish in nooks and crannies? 😵‍💫
A damp microfiber cloth, or a blast with an airbrush, either just air or with some water if it's stubborn.
A child’s toothbrush (preferably not one they are still using).
Going back to the original question, I never polish before glossing, but once glossed and cured I do "flat back" before polishing. I use 6000 and 8000 Trizact pads. Just be careful on corners so you don’t burn through.
If the primer coat shows up areas which need attention - glue marks, poorly filled areas etc - then I sand and correct but always prime the treated area again. Wise words from Andy.
