Bent Photo Etch Fret
I have a problem. I have a new photo etch fret that contains assorted parts for a 1:350 scale ship. It has a bend in it from packing and moving. I opened it up and there was a bend in the middle of the fret. Is there away to fix it? Also, I would like to know if there is a fix for both aluminum and brass for I'm not to sure if it's brass or not for it is silver. Any help would be great. Thanks for your time and help and as always Happy Modeling.
It probably is brass. As for fixing it. I would try to fix the components individually, once removed from the fret for use.
If you have a PA bender try that. Found it works as a press.
Stewart
Heating it gently over a flame helps remove the "memory", but be very sparing - it makes the PE much easier to bend, and too much will make it too pliable! If you have any old, unused PE parts, it'd be a good idea to have a practice run ;-)
As the guys has said, heating can work but you have to be careful, the PE bender can work but again be careful. Other alternative is ask for a replacement set.
Silver coloured etched metal is usually nickel/silver. This is commonly used for etched locomotive name plates etc.
If it is just a soft bend and not folded right over I can't see it being a problem. If it is folded and flat, gentle heat and let it cool. Then unfold it as best you can. Then flatten the parts as you need them.
