Hello again,
first photo shows instructions.
No matter how I tried they would not both fit in those holes. Was pleased to see on Armorama the following from an expert
"As with most things in life there has to be a dark cloud for every silver lining and in this offering from MiniArt it is the word ‘workable’. The track links have been designed to be workable via a pin moulded on the inside edge of outer lug of the links with the guide horn, the problem is that these pins are so fine that they break when trying to engage the holes present in the other link. Now in the belief that most modellers do not play with their completed models, I do not see this observation as a problem. What we have here is a very accurate set of track links that can easily replicate track sag as needed, but that will need to be glued together just like a popular track that use to be available from a competitor.
Removal and clean-up of the tracks is easy enough if you have a good set of side cutters that provides a clean cut. I have covered the issue of the snapping and so what I did was cut the pin off of one side and then attach the link at the other side and slide home with a touch of glue. "
Good to know its just not me then !!!
Needed so really good cleaning resulting in
When nearly dry I put then in a track jig
Nice to use it for the first time .
The only complaint I have apart from the pins on the links being nigh impossible was the instructions, very little other than saying there were 36 of each links per side No mention of how many for the drive and idler.
Ready to start.
Nearly ! added two more and left with a damned gap
Section of half a link perhaps ?
Oh well better luck on the other side hopefully.:disappointed:
John.
