I have for a long time wondered if chipping could be done using a brush and a long drawn out process
I have now found one thanks to ian m ,
On seeing ians AR196 i mentioned that was a shame you cant do this with brush painting ! Ian mentioned liquid mask but he mentioned that it can have ammonia so its best not to use it with acrylics
But this got me thinking and i came up with PVA now ihad tryed this previously with mixed results on large areas but for what i wanted to do it might work on corners and edges so i gave it ago and its not as good as the layered AB approach but its not that bad
Its so basic its laughable just paint your surface add a bit on the end of a small brush , dry with a hairdryer medium heat about twelve inches from the spot for a few minuets and let it cool , pai t your top coat and leave to dry naturally once dry brush lightly with a sued brush until it starts to pull the pva away and it leaves a flake effect
Heres some pics View attachment 77245
