You have more of a chance of getting the fine mist rather than heavy droplets nearer to the spray nozzle
As Steve points out airbrush distance and pressure can affect the coat. I tend to do a 50/50 mix of paint and thinner and see how that goes. Generally I do around 20psi and adjust the needle nozzle for a finer or wider spray area. Depends on if you want mist coats and build up or are after a detail line etc. And yes, even that can and does go wrong.
