Chris's 1/144 Ye-2 Conversion
Steve-the-Duck
Chris
Medway Towns
Okay, the Ye-2 (X-2) was one of several prototypes leading to the MiG-21. The Ye-4 was the first delta-wing prototype, and both flew at a Victory Day parade, resulting in the Ye-2 getting the reporting name 'Faceplate', and the Ye-4 'Fishbed'
'Fishbed'
Really
There are a number of detail differences between the -21 and the Ye-2, though basically it's a -21 with MiG-19 wings, so...
The Trumpeter F7-II is widely available, and, usually, cheap. I've got a stack of them to do various early -21 prototypes. I just need to start making full-length canopies
The Attack MiG-19 has two kits in the box, which is nice
On top is a Gashapon 'Area-88' MiG-21F-13, which is accurate enough, with chunky details, which will be providing the canopy.
If you're unaware of it, 'Area-88' is a manga and anime series about the civil war in an east African desert nation, the two sides of which are rich enough to hire mercenary pilots and buy any jet from around the world to fight and die for them. There's an old set of ten 1/100 kits of some of the stand-out 'planes, some of which were later re-issues by Revell
Excellent stuff steve - cold war soviet , tick - obscure prototype , tick - kit bash , tick
This is everything right up my street , cant wait to watch this one , cheers tony
Are we at the start yet?
All these parts for one little 'plane. Okay, there's three full kits here...
Lots of plans. none of which are actually relevant to the build!
And a bit of light reading for reference material!
So, the plan is:
Fuselage of the F7-II mated to the wings of the MiG-19. That's the easy bit
But there's a lot of small alterations to make:
Narrower chord tail fin
Higher mounted tailplanes
New airbrakes under tailplanes
Two ventral fins
Leading edge slats on wings
Re-positioned guns
Shorter nose
So, completely straightforward!
So, the plan is:
Two ventral fins
Re-positioned guns
Shorter nose
Good thing you're working in a scale that makes that easier... oh wait, in 1/144. zhelayu udachi (according to google anyway).
Just wait till I get to the paint stage and have to mask all the different metal shades like the source photo!
So, I've made a start on the fuselage alterations
Before - I've already cut the solid part of the cockpit rear off
And after, with the strake halves and taiklplane roots removed. From the first pic you can see how much surface detail is engraved. I'll probably fill the whole lot for painting
The nose has to be shortened by a whole one-and-a-half mil (20cm on the real thing!), but that should be easy enough as the whole cowl, intake and shock cone is one piece
The tail just has to have the leading edge cut back
The wings... I may have to cut the wheel bays out of the F7-II wings and shim them into the -19 parts
Well, I thought I was being so clever
I've got a clutch of Trumpeter Chengdu F7-II kits, as they're the closest thing to a MiG-21 F/F-13 you can easily' The plan was to use them for prototypes and early variants, like this Ye-2, the Ye-2A, Ye-4, Ye-6 and others. I'd need to make a new full length canopy replacement tho, as the F7-II has a solid rear. I've also managed to pick up a couple of F-Toys blind box F-13s, which is nice
And then we compare the two, with a set of 1/144 plans I've managed to scale down
Top is an F-Toys F-13, in Egyptian colours. Bottom is the Trumpeter
So, checking dimensions online, the F7 is something like a meter longer than the F-13. So much for shortening the nose by only 1.5mm. It's more like 7 or 8 mil!
Not insurmountable though. Just a question of where to cut. And that the F7-II wings are very slightly further forward too. GAH!
I've already filled some of the unnecessary panels and vents
Well, at least the re-shaping of the tail fin went okay
Top is the basic Trumpeter piece, middle another F-Toys F-13, bottom the finished Ye-2 fin
This may also have been a mistake. I'm not sure yet
Rather than simply filling the wheel bays on the MiG-19 wings, I decided to cut out the centre section of the Trumpeter wings, leaving the locating tab on, and cut-and-shut
Just need to do a little filling and sanding now
It'll work
And if it doesn't, I've a whole 'nother wing to play with!
And I think adding properly folded PE is an accomplishment!
Crikey Chris, talk about attention to detail. This work would be difficult enough on a larger kit but in this scale I am impressed.
Still plenty of time for everything to go horrendously wrong
More Wrong
And to think, donkeys years ago, me and my partner decided we were going to build the MiG-21 variants in 1/72, as there were plenty of kits available
Except for a decent F
We did do a Ye-2A and the Ye-4, but that was all
Okay, here we go, quite a bit further with some inspiration and not making planned missteps
I did think I was going to have to do a few cut and shuts, but lining things up with the 1/144 plan of the F-13, I discovered the nose, without the nose-cone, was about the right length, but it would still be too wide around. So, from my ubiquitous Ju-88 spares, I found a ring of about the right diameter. You can see here just how far I've cut back to, which will give me the right length. The nose has been filled, so I can sand it back to the right diameter
I've also discovered the F-Toys F-13s may be a little short
At least now I've got a method to use all those F7-IIs as intended. But one will have to be built as is
With the modified fin on, it's angle gives it the right straight top. Might paint some belts on the seat.
When I do the delta-wing Ye-4, I'm probably going to use the Area-88 model. When I finish this!
So, the wings have had to be shortened by 3 mm to get the correct span. They're not an exact crossover with the MiG-19
Filling, filing and sanding worked pretty well. Might re-scribe some of the lines before attaching. The unmodified wing is on the left, and I might take a simpler route to make the wheel bay on that one
