This is probably the largest injection moulded aircraft that you can get with its 42 inch wingspan. The main issue was with the size and the problem of working the kit without the extremities getting knocked around! The fit is good to very good, the detail is OK and the accuracy not great with the wing profile being the big problem there. The engineering could be better particularly for the rear turret (and front one on the later version).
Companies like HKM could have done this better than HobbyBoss, for one thing they would have had better and more thoughtful engineering. But, at the end of the day, we are lucky and should be thankful that a company has actually released a 1/32 Liberator.
That underside shot was difficult to do as I did not want to put the aircraft down on its back.
