As the title says are there any photo etch benders for doing curves
Something like that as I was doing the curved bow rail on a titanic I am working on and found I jolly difficult to do.Peter do you mean for making tubes, round items ?
That is the only way I know other than to make it out of 10th plasticard which is about the thickness of etch brass.Something like that as I was doing the curved bow rail on a titanic I am working on and found I jolly difficult to do.
I agree with Tim: a cheap solution is to press anything into service for another purpose. Drill bit shanks, even guide rollers that I kept when stripping down a computer's DVD drive.You are better off using an appropriate household item as a former
Thanks that would definitely be the thing but I will have to set aside the pennies before buying as I will have a lot of pe work coming up soonIs this what your looking for? Rollers
You could do that with some mild steel bar offcuts and some cheap V blocks.Thanks that would definitely be the thing but I will have to set aside the pennies before buying as I will have a lot of pe work coming up soon
