I started this 10 months ago and finally got round to finishing it. It needed quite a bit of filler and a lot of work. It's not perfect but I'm happy with it. I built it out of box including the 35 year old decals. The glue on the stencils showed thru the clear carrier film. So I floated the decals off the paper into a bowl of water. Then I cleaned the glue off, put them back on backing paper and applied them to the model with micro set. I used an HGW fabric harness in the cockpit. A bit fiddly to assemble but worth the effort. I will definitely use them again. The build started out as a mk24. But I eventually finished it as a mk22 of no.603 'city of Edinburgh' sqdn from 1950. The two marks were identical apart from an extra fuel tank in the mk24's fuselage.
