DaveCov's Aoshima 1/700 IJN Seaplane Carrier Chitose (00123)
Another little update.
I got out the airbrush and primed many of the parts:
Major components:
Photo etch pieces:
The aircraft:
That is all for now.
It has been a couple of weeks since my last report but not too much has happened. Having primed the parts I got down to painting. I decided to brush paint this build but I may end up regretting this decision.
I applied the first coat of H123 Satin Extra Dark Sea Grey but it was obvious that it would need another coat:
The other parts:
I then applied a second coat of the grey and started painting the other decks with Colourcoats Matt Linoleum (IJN10):
Some of the grey parts won't need a third coat but some will:
The inside of the crane booms, catapults and trolleys were painted grey:
The other parts:
Some tiny parts for sure there Dave!
.... Gotta say,those planes look very nice indeed :thumb2:
Thanks lads.
Having applied a third or even fourth coat of grey and linoleum, I am pleased with how things are turning out.
I haven't glued the decks or superstructure to the hull yet as I want to fit railings first. However, I wanted to see how they fit after painting. In the background, I have applied some light grey to the aircraft undersides:
The platform has been dry-fitted too:
At the moment the paints are a mix of satin or matt but once everything is varnished it won't look so shiny:
Lots of progress to report.
The aircraft painting continued:
And it is now complete. Just the decalling to do:
The decks were glued to the hull:
The hull was masked for painting the anti-fouling and also to protect the hull paintwork during the task I hate more than any other - small ship PE railings. Here the forward and amidship sections has been done:
The aft section:
Superstructure decks also done:
Turning to the platform, I glued the two booms in place:
The photo-etch crane jibs did not have any blocks so I painted the kit ones and added them to the PE:
The crane booms were then glued to the platforms and later I would clean up the paintwork:
The superstructure has been glued in place along with the boats:
Another view. Not a lot to be done now:
Good to see your progress with this one, I will be tackling a small ship soon too......
Thanks lads :thumb2:
I have had a few problems with the PE aircraft cradles and they keep snapping so I replaced them with kit parts. In view of those problems, I am going to leave off the PE cable reels. The amount of grief isn't worth it!
Here I have been progressing with the aircraft. I decalled them and then painted the floats white as a base for red paint. This was not without a big problem. Whilst holding the bottom right plane with tweezers, it pinged off and did a Kamikaze dive straight into the white paint pot! I retrieved it and cleaned off the paint, leaving it in the scrappy state you see:
Turning to the Chitose, I painted the anti-fouling red and removed the masking tape. The catapults were fitted and four aircraft glued in place:
Rising Sun flag fitted at the stern:
I still have three aircraft and four davits to fit and need to apply a coat of varnish to everything.
Final build report now.
The last three aircraft were glued to the forward catapults and aft:
The four remaining davits were painted and glued to each side. Final act before varnishing was to paint the Imperial Chrysanthemum at the stem with H16 Gold:
The whole ship was then given a coat of matt varnish:
It is now finished:
My thanks to @KarlW for hosting this GB.
Cracking build Dave, and a ship away from the norm. too!
Very neat. I've enjoyed watching it come together.
Ron
Blimmin Eck Dave...
... That's come on leaps and bounds since I last looked in!!
Looks absolutely great mate, congratulations, awesome stuff :thumb2:
Thanks everybody for your kind comments. :thumb2:
After my initial misgivings about brush-painting, it turned out quite well in the end and allowed me to finish it a lot quicker than if I had airbrushed it.
