Display case
Bri62
Hi guys/gals
Hope this is the right chat, I started thinking about displaying my 1/200 HMS Nelson but struggling to find a enclosed case big enough any ideas?
Brian
Perhaps a 120cm (47.2") fishtank?
Other than that I would order glass panels, glue them together and finish the corners with a small plastic/metal corner profile or something like that...
There are firms that do custom acrylic cases out there, just a matter of googling for them.
HI Brian well a display case for your big 1/200 NELSON will not be cheap better way of doin what Steven000 says an that will still cost though but lookin forward to your build blog on here though
chrisb
If you don't mind a frame you can make your own pretty easily. Fish tanks are relatively expensive, a 4' tank needs to be strong enough to hold about 160kg of water.....
I built a cabinet for my 1/200 Hood and just had plexiglass doors. (could of used glass but cost to much).
If you are good with the tools you could make one for a fraction of the price of buying one.
There are also glues made specially for Acrylic sheet.
Brass angle cut and soldered to size then glued to the sheets would also work.
