- Joined
- Dec 28, 2023
- Messages
- 2,784
- Location
- Swale Kent UK
- First Name
- Peter
Had this for a few days (maybe couple of weeks) now.
I am a total Dspiae fanboy and make no excuses for that. IMHO they make good gear at a reasonable cost.
I have uploaded a short YT video of my first impressions of this grinder, see linky below:
YT video of Dspiae grinder
It seems well made of good quality.
NB: It is only a mini and cordless (usb rechargeable) grinder, so don't expect it to clean up your welding!
Its only designed for scale modellers and the soft plastic that we generally use.
I bought a set of carbide grinding bits that work fine with it and as far as I know it has a 3mm hole/collet,
so should work with most Dremel type bits, (Edit, erm Nope! see comments below....)
so could be used with bits/attachments for drilling, sanding, shaping, as well as grinding.
It has three speeds, so far the first/slowest speed has been fine for everything I've used it for.
Its a handy bit of kit and is certainly faster than sanding if needing to remove larger sections of plastic.
Link to John's SMS shop page:
SMS Dspiae Grinder page
