If you see a wriggly thing on the right of the previous image...well that's the snake made from bent wire and putty... the wire is brass coated with metal primer so it doesn't oxidise and ruin the paint applied later
Rough shaping the putty round the top and when cured will add more putty detailing and shaving off extra bits. I sprayed Mr Surfaces in layers to build up thickness to parts of the body.
Made the horns and fangs from bits of plastic cut to shape glued it on with CA and strengthened around with more putty.
Finally drilled out the eyes and now awaiting painting.
Wabble
Finally drilled out the eyes and now awaiting painting.Cheers,
Wabble
