The result of this evening's work. The left fore leg has been strengthened, not because it is a supporting leg but because it was cut into 3 parts and I know that if I just glued them together they are likely to brake during the build/painting process - better safe than sorry!
I used milliput and paperclips to join the front and rear halves, when the Milliput is set (tomorrow) I will fill out the middle parts of the two halfes and fit then together. Being fixed together with paper clips gives some flexibility to bend the sides if necessary.
