Hi guys,
I don't know if this is the right place as I'm still experimenting after seeing it on Youtube. I'm restoring my yellowed vacformed canopies back to it's original clear form.
The basic ingredients needed for this process is Hydrogen Peroxide and UV light. Apparently the very thing that yellows plastic it UV light and although it was thought that it cannot be saved someone found a way to reverse it by applying hydrogen peroxide with UV light. The video shows it working so I thought I might as well try it.
Since the canopy part is small, all I needed was a small transparent plastic food container and baking foil. I wrapped the container with the foil to act as a reflector of the UV light rays. Fill the container with the hydrogen peroxide solution which I bought from the pharmacy. Try to get one that's pure or at least more than 3% for it to work better. Then I submerged the canopies inside. For UV I used the natural sunlight. I have only started today and so far I see some bit of clearing.
There is a reaction with bubbles forming on the surface. I will leave it for another two days and see what is the outcome and keep my fingers crossed that it works.
Here's the Video on Youtube if you'd like to see they do it. Obviously it's a better set up with UV LED's.
