Been busy finishing off this bird. One of the best fit kits I have made so far - as good as the Hasegawa TF-104G Starfighter. Only small critisisms for me is the longitudinal canopy seam that had to be got rid of, and for me the decals were slightly on the thick side although the print was excellent. Attached are some photos which I hope you like, details of the paints used and some of the techniques for removing the seam and painting the inside of the very long air intake can be found in the 'under construction' section. I have included the last photo as requested by Paul (AKA Trickey66) showing all my low-vis aircraft, all are 1/48 except the 1/72 Typhoon. Cheers Derek
