From a photo papa 695s ME 109
papa 695
Staff member
What a result. Excellent build...You choice was a really hard photo to copy, but you've made a cracking job of it.
Very well done.
Ron
Sorry ian it can't be accepted ! Where are you mountains ? And there is no frame in the real photo :D :p
Seriously though that is very good , colours are great and position is fab it's a real top job there :)
Excellent job Ian..... the paint work and finish on the 109 is spot on well done.
scott
That is brilliant.
Well done in all categories. Build paint and base.
PS added the Great Build do dab to the GB and SIG sections... I hope
unbelievable Ian, this is just superb . Its exactly the same as the photo, job done. fantastic work mate , cheers tony
That's a cracker Ian. It looks thoroughly convincing. What is your product of choice for creating the water?
Jason
Brilliant result. I know it's not the focal point, but your water is quite something else.
Just brilliant, Ian. My eye was drawn to the water, too - so realistic. The damage on the plane is beautifully done, as is the worn paintwork. Give yourself a massive pat on the back!
Thanks for the great comments guys and the great build doodabs.
To be honest I'm not entirely happy with the water I wanted to make it with more ripples but I had to go to work before it fully cured so it settled more than I would have liked.
Jason
Hi Jason many thanks for the great comment. I used clear cast resin for the water on this one
\ said:
Definitely a great build Ian! I like yours better than the photo :)
Many thanks Patrick
But like I said in the earlier post I'm not entirely happy with it
great job Ian ,your done so well with the copy,and damage to the plane,
with the weathering all so ,lov it, :D
what did you use for the water looks like a mirror, ;)
Thanks Monica I used clear cast resin for the water not cheap but it does the trick ( at times )
it pays off to use the right stuff,ta,
i never get the mix right with the resin and harder ,so much to so mean drops,
