Geoffs Revell 1/72 Fw 190 A-8 & BV 246 “Hagelkorn”
Geoffers
Geoff
Shropshire
Well here we go with my entry.
Click image for larger version  Name:	IMG_3976.jpg Views:	82 Size:	347.9 KB ID:	1245023
I don’t build Luftwaffe kits as a rule but wanted to join the GB as a tribute to Alan, I hope I can do it justice 🤞.
This kit is from the 1990s when Revell were knocking out some decent kits and this looks to be no exception 😊
Here’s the plastic.
Click image for larger version  Name:	IMG_3977.jpg Views:	75 Size:	287.3 KB ID:	1245024 Click image for larger version  Name:	IMG_3978.jpg Views:	76 Size:	292.2 KB ID:	1245025
Click image for larger version  Name:	IMG_3979.jpg Views:	77 Size:	321.1 KB ID:	1245027Some nice refined surface details.
Click image for larger version  Name:	IMG_3980.jpg Views:	77 Size:	245.1 KB ID:	1245028 Clear parts.
Click image for larger version  Name:	IMG_3981.jpg Views:	77 Size:	583.2 KB ID:	1245029
Instructions - Old skool Revell 🙄
Click image for larger version  Name:	IMG_3982.jpg Views:	77 Size:	238.6 KB ID:	1245030
Transfers - no Swastika’s
Now a bit of history from Revell:
“During World War II, the Focke Wulf Fw 190 proved to be the
most versatile single engined Luftwaffe aircraft.
Over the years the fighter-interceptor became a fighter-bomber, torpedo
bomber, fighter and two-seater trainer. In addition the Fw 190
was increasingly used for testing complete weapons systems at
the Luftwaffe proving stations. Thus various versions came to be
used for testing the Blohm & Voss Bv 246 „Hagelkorn".
The Bv 246 was an automatically controlled glide bomb which was
originally developed to replace the Fieseler Fi 103 (better known
as the V 1). The Junkers Ju 88 A-4 was designed as a transporter
which would carry up to three of these machines in action. Howe-
ver during trials aiming was not sufficiently accurate and the
programme was discontinued for the first - but not for the last
In July 1943 the Karlshagen proving station received an order to
test the Bv 246 which started with a Ju 88 and after that was lost it continued with the Fw 190. However the planned production
was interrupted several times, until finally there only remained a
series as target practice for the anti-aircraft guns. Between July
1943 and July 1944 a total of about 238 Bv 246s were tested with
different control systems.
Testing with the Fw 190 and Bv 246 was abruptly halted in Karls-
hagen when all the remaining 29 Bv 246s were destroyed in an air
attack.
A total of 1,100 type Bv 246s were built.
Span 6.41 m, Length 3.53 m, Diameter 0.542 m, Weight 730 kg,
Explosive charge 430 kg”
Hoping to get started soon, thanks for looking 👍
Geoff.
That some very interesting background Geoff. Looks a nice kit. Revell kits are quite varied in quality but this looks more than ok. Let's hope the fit is good.
This is identical to my kit....i even get the un needed glide bomb
thing is you didnt get the flash i got 🤣🤣
Nice choice geoff , its not a bad kit at all , cheers tony
Cheers Steven it does look like a good little kit, hopefully it goes together well too 🤞
Thanks Jim, yes I’m keeping my fingers crossed 😊
You mean you didn’t specify the flash free version when you purchased yours Paul? 😂
Thank you and good with yours too 👍
Glad to have you along Garry 👍
Thanks Tim, I was surprised how many roles the Fw 190 performed 🤔
Interesting addition with that glide bomb Geoff. Must have made take offs more difficult though. Following along....
Nick
Cheers Nick 👍
Yes it must have been a bit unwieldy but not as bad as with a torpedo which I believe they carried 😮
Well I’ve made a bit of a start today 😊
Cockpit parts cleaned up and painted in the base colour.
No decals for the instrument panel and side consoles so some detail painting required 😱.
I’ve ordered some photo etch seat belts which should hopefully arrive soon.
I’ve also put the glide bomb or Hagelkorn together which Google translate informs me is German for Hailstone.
IMG_3985.jpg It will need a bit of tidying up before painting.
So not too much done but once the cockpit is done it should be 🤞 a fairly straightforward build.
Thanks for looking 👍
Geoff.
