Oh nice one. I'm so trying that one. I find sometimes the thin is too thin but the regular Tamiya goop to thick.
Thinking out loud here: Does this mean you can make 'clear' filler...?
I started in the 1960s when the only glue available was polystyrene cement in a tube that you pierced & sealed with a drawing pin
AFAIK it's just a solvent with clear polystyrene dissolved in it
Later came liquid glue, which is just the solvent, in bottles with brush caps or bulk in plain bottles
I started with Humbrol, then tried Tamya and Mr Hobby/Mr Cement, which I prefer as the bottles are better
However I find that sometimes liquid glue flows around too much, so I added a few pieces of clear sprue to the Mr Cement; no special reason, it was a 50;50 choice between that and Tamiya
This makes it slightly thicker so it doesn't flow over small parts, but nowhere near as thick as tube glue
You add a few pieces at a time, till you get the viscosity that suits you.
I use the thin for flowing into joints and the thickened 'my mixture' is applied to joint surfaces before the parts are quickly pressed together
Experience will show how much to use, if you get it right there's nothing squeezed out.
I've had both of those bottles for a while, and I prefer Mr Cement as the cap is longer than the Tamiya and easier to hold, so motivated by this Thread I've ordered some more Mr Cement -
As we know, Mr Hobby has loads of products, and their website explains them
www.mr-hobby.com
I've ordered -
Mr Cement S : code MC129, standard thin liquid glue
Mr Cement Deluxe : code MC 127 slightly thicker, stronger bond. It's thickened by adding plastic & resin, so it's nice to see that Mr Hobby agrees with me!
I've ordered them from
www.modeldisplayproducts.co.uk and I'll see how I get on with them
As you might have gathered, I'm not really bothered about any particular solvent, as long as it does its job; aficionados might have their preferences but as far as I'm concerned they're all much of a muchness
I have emptied a Revell Contacta dispenser, various bulk liquid glues, and a manky old tube of glue into bottles of liquid glue and it still works
Yes, the viscosity might change but you can adjust that by adding sprue or solvent as required
As my new bottles of Mr Cement get used up I'll top them up with my existing plain or thickened glue, and bulk liquid
I've heard of making liquid polystyrene filler & seen videos about it, but I've never used it myself; perhaps one day soon.
There are also several videos about choice of glue
