Pictures are there...but as attachments..,.Thanks all, bit more work, just hope the pics work
No!!
As per email will have a look later!Sorry not doing a direct reply but it's a nightmare typing etc
Did that post ok Bob?Cheers Pete, appreciated
Typed ok replying to you no, I typed BUT after ok as you can see it jumped to the front as it is now, plus typing inside the reply box and not in the white area BUT
Odd.... Very odd.... Never seen that before..... Well try to have a look tonight....but it is meant to be date night.Hi Chris, Not a clue but Andrew is very generously working with me to hopefully find the problem. As per the ship I have decided to only post again when it's finished
Looking good Bob. Glad you are making progress on these floating fortresses. Nicely detailed kit as well.Another test
The superstructure is going to be fun
The superstructure is not fitted I have to add the wooden deck first
The upper superstructure first deck has a lot of I think 4pdr guns, it's going to be impossible to add the roof to the area and then fit the guns. I am going to have to prime/paint the deck and guns then paint the roof and then add that, fiddly. You can see the upper deck and the end but which also have support struts. Should be fun. Starting the pe next, the admirals walk at the bow
