The paintwork is fantastic great work so far
Funny, I always like loading up my models with lots of scratchbuilding and resin with PE, although 50% of it isn't seen. It gives me a sense of satisfaction....\ said:Yes it's a mixed bag. When I did Jets I liked the Eduard 'Zoom Sets' for the cockpits, and depending on the model maybe an exhaust. Problem is I don't have a local model shop, so when you are buying a kit online you try to cut down on postage and get everything together, and with PE you very often are buying blind, and get disappointed.
When I did my EE Lightning, I bought a resin cockpit etc. etc. which wasn't cheap, and when you fitted the very small canopy everything in the cockpit was hidden - a big waste of money. Moral of the story - do your research first. Cheers Derek
I probably would had got an aftermarket replacement or trashed it if that happened to me. Good to see you are sticking through this build.\ said:Thanks for all the positive commentsGang!
Ran into a mystery of sorts,this damage mysteriously appeared over the weekend. No explanation can be found as it was not near any heat source at all,very wierd,
No sense fretting over it,after I got over being angry I dove in and fixed it. I cut the rudder away and filed the edges flat on both surfaces. Then I added some sheet styrene cut to fit,then filled gaps and seams with thin ca. The surface still needed a little green putty and after a final sand and rescribe I reattached the rudder and primed the repair.
Now I can get bact to fitting the cable fender!
Your very lucky Trey that could've gone up in flames very easily.\ said:Found the culprit for the mystery damage,my magnifier! This time of year the Sun is at just the right angle to come in and hit the lens, will be keeping the drapes drawn until the afternoon from now on!
