Kressy's Hasegawa 1/48 109 F4 GB Build.
Kreston mate.... 3 tone camo, firstly hats off for event attempting it, and secondly very very well executed man! Thirdly getting that propeller top right can be such a pain but I think youve done well.
Thanks mate. Getting feedback like that certainly helps to push me along and do a good job of it. Hopefully be getting the decals on in the next couple of days.
Cheers.
Quick question as I'm doing the decals. Would the tail victory markings be on both sides of the tail or just on the one? Can't find pictures that show the starboard side of the tail.
Cheers.
Now that's different. Three tone camo... Nicely done Kresten.
Thanks Ian. Well I have the main decals on, just the smaller stencils to go. starting to look better now. Need to try draw the maxi under the cockpit as it doesn't come as a decal in this pack.
On another note I won't be getting print scale decals again. Poorly printed and took quite a but to get them to settle.
Cheers.
Looking very goooood there Kreston mate. Good job on the decals.
Thanks guys. They are a little John. Think I had the blu tac a little close to the surface where I had the demarcation. Just have to practice a bit. Way out of practice with my airbrush as well. Hahaha.
Still trying to do the stencilling. Managed to fracture my thumb last week so it's going a bit slow at the moment.
Cheers.
Cheers.
Just a tip mate, you can try freehand camo. You can attain excellent results with it, but I guess for this tight a demarcation it is a little difficult. You can try blu tacking some card 1mm from the surface of the camo to be sprayed, and that will create a hard edged, yet slightly soft edge
Thanks mate, might have to try with the card in future. I normally try to freehand the camo but as you said it's a bit hard to get the hard demarcation. Just need practice.
Cheers.
Looking very nice. I've never seen this scheme before, looking forward to the finished build.
Thanks Colin. I hadn't seen it either till I got the decals. Well I've made a bit of progress with it. Got the decals done and a clear coat on. This is the underside done with a panel line wash. Still got the top to do plus all the other weathering.
Cheers.
I think it looks good, the panel lines and rivets are also very nicely highlighted there.
