Kursk. II S.S. Panzer corps slowly claw their way toward Obayan
Paul your figure painting skills are of the highest order my friend most beautiful you have a talent there and if the rest turns out this well iam very keen to ses this develop further, very well done indeed my hat is off to you sir.
scott
Thanks guys for the comments it means a helluva lot.
Graham: I know you don't need any help with your figure painting, although you do seem to have quite a few to complete! How many is it exactly?!
I've got 9 altogether and the one I've nearly finished took me a week and a half! 4 months doesn't seem that long a time period now does it!!!
Ron, Tony, Martin - thanks again for the support. The encouragement here helps to maintain the enthusiasm levels! I hope that my comments do the same for you.
Paul
Ps. For the next part of the build I'm concentrating on the diorama base!!!? as I need this in place for parts of the build later on.
Cheers Scott
I was writing my previous reply when you made the last post. Thank you too and I do hope that when you've finished your masterpiece Dora you'll have time to join us.
All the best
Paul
I dare not count them at this stage Paul but it is around 16 I think. I am getting the vehicles done up to the weathering stage first as I need to shuffle them around on a base board to get my positions right before I plan out the landscape. At that point I will decide which if not all to use.
\ said:
OK Paul, I have posted all my figures to you to paint and I have included a couple of quid to buy yourself a pint for doing them. Don't tell anyone else on the forum so that when they see them they will all think I am a genius.Just superb mate, really good.
Yes, Yes what Graham just said. I'll pay you in oil........... Just kidding, Jeff (in USA)
wow paul!! that figure sure turned out great! you've got alot of fine detail in there. i really like your camo smock and helmet. can't believe you've got 9 to do! and graham too, 16! thats heavy backbreaking work. i've almost finished the 4 of mine and i think my spine's gone funny.
well paul, if they all turn out like that wee bad-boy then this is gonna be a dio to see. can't wait.
That figure is simply amazing. Great job. Cant wait to see the rest now. Great work.
Kresten.
Thanks guys for the kind comments. I'm really glad you like the figure I'll try my best with the others and hopefully the dio will come together ok.
I am glad I'm only doing the 9 though and not 16 as Graham is! (although he may omit a few). Having said that, I do think figures add a great deal to a diorama and add a lot to 'the story' of the piece.
Paul
Hi everyone
I've got some updates on the Kursk dio...
After completing the first figure I turned my attention back to the base as I need the terrain complete before I can complete the tank.
First I stuck the layers of foam board on to the MDF base using PVA glue. At this stage I also shaped the foam a bit using a hot wire.
View attachment 17181View attachment 17182
After this dried I covered the base with a layer of plaster bandages - this will provide a firm base for the rest of the layers. I was careful to make sure that the bandages closely followed the contours of the trench as I didn't want the shape 'softened' too much. The contraption on the right of the photo is the hot wire.
With this drying I continued with the T-34 suspension I started last night. Now the AFV Club kit has 'working' suspension and I intend to use this to full effect in the dio. This is the reason I need the base first so that I can conform the suspension to the terrain. The build went together without too much bother, the only amend I made to the suspension was to shorten one suspension rod to enable the arm to fully depress right up to the suspension stop. The reason for this will become clearer later in the build but is to do with 'knocked-out' portion of the tank. I built up the wheels so that I could position the tank on the base once dry. You may notice that some of the tyres are missing, this is again part of the 'knocked-out' build as I wanted some of the tyres burnt off the rims (it is fantastic luck that this kit actually has separate tyres!)
View attachment 17184View attachment 17185
I decided I didn't like figure 1 - it just didn't seem animated enough, so I decided to turn him into the soldier leaping the trench. This obviously involves a lot more alts to the figure than the NCO but I was encouraged by the previous effort so, what the hell!!!
I cut his limbs through the joints and drilled into them inserting copper wire. I had to fill the body once I'd cut into it because the torso was hollow at the top of the legs. Once this was dry I was able to drill it and insert the legs. Further details will be added but this is the basic structure. Obviously he's looking a bit skinny at the mo and really needs to hit the gym but I'll bulk him out once I've ensured the pose looks right on the base.
View attachment 17186View attachment 17187View attachment 17188
...one last thing...
I built up 1 of the tracks from the working set last night - what a dull task that was. Built this in front of the telly watching Uruguay v Holland to relieve the boredom!!!
I have to say they do look good though and are necessary for what I have in mind for the dio.
...and that's about it for now...
Paul
Paul, blinking awsome stuff again matey, that fig is ganna look brill when complete bud. Loving the start of the dio as well. All the best mate, Martin :-)
thats some insane work there paul! your completely re-making that figure. thats fantastic stuff.
Thanks for the comments guys
Bobby - I'm blaming the individual link tracks for my insanity (thankfully both sides are done now!):lala:
Martin - if all goes well I'm going to try and make this year's Euromilitaire, I know you mentioned you we're going.
Paul
Brilliant stuff paul, the reworking of the figure is really admirable, pushing yourself to see what can be done, i cant applaud your attitude enough! Cant wait to see him when hes put on a bit of weight! cheers tony:terrific:
\ said:
Thanks for the comments guysBobby - I'm blaming the individual link tracks for my insanity (thankfully both sides are done now!):lala:
Paul
Will be brilliant if you can make it bud, dont know if you have visited their website, well worth it. There will be a beer waiting for ya at the show mate...all the best Martin :-)
Hiya Paul, those figures are top class, love the oakleaf camo looks so real. See the T34 coming along nicely as well they are absolutely great kits.
This is gonner be a fantastic!
Ade
Thanks Ade, I'll be following your build of the AFV club T-34 with interest - you've made a great start.
Tony - thanks for the support. If 'skinny' turns out ok then I think I'll have the confidence to tackle most figure mods but I don't want to get in front of myself - I'll just see how this goes first.
Martin - If I manage to get to Euromilitaire we should definitely meet for a drink. I have been once before, it's a great event with some breathtaking models. Be warned though your credit card may take a bit of a hammering when you get to the retail stalls!!!
Paul
Im already popping me spare money in a jar for this show bud. Ive paid for me accomidation x2 nights...its ganna be a blast :-)
Ita always a pleasure taking delivery of goodies like these from the postie :-)
After a busy week not much progress I'm afraid...
'Skinny' (Figure 1 from the original line-up) has put on some weight though.
This is a list of the modifications to the figure:-
Removed his head and hands these have been pinned and will be added later
Hollowed out the sleeves
Given the smock cinched sleeves
Added smock over tunic
Enhanced the collar
Added tie placket on front of smock
Altered feet to better reflect movement
... and obviously the positioning of the limbs...
Here he is so far..
View attachment 17357View attachment 17358View attachment 17359View attachment 17360
There's still quite a bit of work to do on him yet - tidying up the putty work, repairing the hole in the sleeve (went a bit crazy when hollowing the sleeves out!) and adding the straps (from lead foil) and the equipment.
And then it's time for a splosh of paint...
I'm not going to bother posting all the mods on the figures (unless someone desperately want's me to) as i think it will be a bit monotonous. I'll just post all the German figures when finished. I may post the Russian soldiers as these again will require a bit of work to get natural deceased poses that fit into the diorama well.
The only other thing I've done on the dio is edge the base just to make it look 'nice' as it will get a wood veneer toward the end to finish it off.
P
