Large and Small Scale Figures
Some good figure painting there Steven. I especially like Sargent Knows with it's interesting needle work that shows even the toughest men can do these things.
Noticed also you do the big stuff and painting those can be challenging.
Wabble
Just fantastic Steve Sorry i missed these.I still use oils on faces and the late Eddy Vandersteen kindly gave me good advice.I havent painted figures for 7 years.Never done uniforms in oils.Mainly use Humbrols and Revell enamels.
Stunning work.
Stunning work Steven.
Your figure painting skills are top notch. I especially like the Highland Infantry and Arnhem vignettes
ATB
Paul
Wabble
Thanks, Wabble!
Stunning work.
Richard, you're giving me flashbacks when you say you're using enamels to paint uniforms. When I learned about oils I was using only enamels, acrylics hadn't come into the spot light yet. Once I saw the "blending" properties of the oils the enamels went into mothball and have pretty much been there ever since.
If I may suggest, try some oils on a set of trousers to see if it's making things easier than the constant hassle commonly found with enamels. If ya like em, awesome, if not, ditch em and carry on. Whatever works best for you is how to work it. My initial oils test run was on the Adolph Galland figure above. Once I saw how the blending actually works and how nice the trousers came out I worked the leather coat. I've never looked back since.
This is art.
Thank you, Andres, mucho apreciado!
ATB
Paul
Thanks, Paul! The Highlander figures were incredibly well sculpted, total talent on the Vladimir's part. The Arnhem set as well, Stevo really did a great job on those, too! A very well-known point when it comes to painting figures is the sculpt. If it's done really well the brush pretty much does the work for you, otherwise it's a battle to the finsh.
Thanks for the tips Steve.Ive dabbled with acrylics on faces but find sometimes the look is bit too flat.I have tried using oils over acrylics on faces but not uniforms.Must be tricky mixing correct shades in oils or is it just oils as a glaze over an acrylic basecoat?.
A very impressive collection.
Peter
Thanks, Peter.
Howdy, Richard. If I understand your question correctly, mixing, blending the oils on the figure is very straight forward. I learned to place the shadow tones in the creases, highlights on the ridges, then main tone on the main level first. Then with your brush blend the edges, mostly in a straight notion down, or across, but not always. You get the intermediate tones from the blending, not just having that specific tone already mixed. The blending creates these tonal variations. After you play with this on a large area it becomes easy to understand how it will work in very small tight spaces, the concept is the same. I hope this helps somewhat.
Hi Steve.
Thanks for your response.Do you mix your oils to match the acrylic undercoat?,Im guessing there are more shades now with the likes of Abteilung 501 oils?.
Many thanks.
Hi Steve.
Many thanks.
Yes, pretty much or as close as possible. The blending will vary those tones as you go along, but the main tone should still be present when all said and done.
Some very impressive work Steve, I'll stick with my little figures, easier to hide stuff :smiling5:
Yes, that is an advantage to smaller figs. If in doubt, one can always fall back on the old carpenter's rule, know how to hide your mistakes, HA! I think that's why they invented "sheetrock", the wonder board.
All kidding aside, Mick, thank you. I do like the smaller scales, but it's much easier to refine those skills in a larger scale, imo.
