Looking for a flexible material for edging a curved diorama?
pjgtech
Peter in Kent UK
Swale Kent UK
Peter
An upcoming diorama I will be building will be made from foam board and will have a curved edge.
Once the diorama is complete I will need to cover the curved foam board edge.
The base will be about 300mm in diameter, so the radius will be around 150mm.
What would people recommend as a good material for such a task?
The foam board will be about 10-15mm thick.
It will almost certainly be painted on completion.
Balsa will probably snap!
I could use maybe card of some sort.
I could use some sort of thin plastic card.
I suppose some sort of fabric (maybe a thick stiff fabric) could be used too?
Any other suggestions?
Hi Peter
I would recommend using thin veneer, several types of wood would work. You will have to orient the wood grain vertically to follow the radius.
Hmm, had not thought of veneer, how would you adhere that to the foam board, eg: CA or pva or hot glue gun? or something else...? Cheers
Edit, have looked online and most of the rolls of veneer are pre glued and require heating/ironing, which may cause probs if applying to a foam base, eg: melting, I'll see if there's any non heat glued ones out there.
I would try thin card. It's readily available, cheap, easy to glue in place and will take paint well. 30cm across means about 1m to go all round. Only being 1/1.5cm high you should be able to neatly join shorter lengths.
Its not quite a full circle, but is more than half, so the length I need is about 700mm (70cm) I have just ordered a roll of non glued veneer off the bay of Evil..... 8-)
A nice light American Oak...
I used glue on edging strip for the worktop I use as my modelling desk.
Needed a strong contact glue to stick it down properly.
Have a look at 'Nightshift' diorama videos on youtube.
