- Joined
- Apr 27, 2018
- Messages
- 15,185
Mike,
Your scratch work is outstanding mate. How do you make your tie downs so fine?
Thank you.Mike
This scratch building is second to none - brilliant.
Thank you.I’m in awe Mike.....bloody excellent sir :smiling4:
Those on the front box are from an etch set that I used, normally I would use heat treated thin copper wire bent to shape over a template and then the ends flattened in a pair of pliers. The ones on the rear left rack are started the same except they are bent around a template and then the ends flattened and cut to length. Next time I will show pic of my 'template boards'.Mike,
Thank you.You can really scratch impossible to reach areas Mike...excellent mastery. :thumb2: :smiling2:
