- Joined
- Apr 27, 2018
- Messages
- 15,174
Jakko,
A very different and interesting build.
HahahaWho wants something simple , certainly not you Jakko.
I am also guilty of assuming the duck/duct tape thing....for air sealing ducts! Every day is a school day!Well, as usual I've learned something from this build. I'd always thought that "duct tape" was so called because of its use for sealing joints in ducts, and "duck tape" was a corruption of that, but I hadn't realised that duck tape came first, meaning a strip of duck fabric. I also didn't realise it had been around so long, if I'd thought about waterproofing tanks for shipment (which I hadn't!) I'd have expected them to use Denso tape, or maybe strips of fabric coated with Cosmoline.
Thanks Jakko!
I was long under the impression it was that way round tooWell, as usual I've learned something from this build. I'd always thought that "duct tape" was so called because of its use for sealing joints in ducts, and "duck tape" was a corruption of that
You’re welcomeThanks Jakko!
It’s the having to cut the strips that I find most tiresome. I really should have bought a roll of 1.5 mm wide tape before starting this.Looks great. A real test of patience.
ThanksI agree with Tim - your trademark meticulous research.
I’m hoping it will, with the superglue smeared all over it. I think Steven was right that it might flake off otherwise — just look at how it behaves when you pull masking tape off a model.I'm sure that paint will stick to the tape. Will you have to paint all the taped areas a different colour to the body?
