Masking over decal area
Any one with any ideas gratefully received.
Have a problem where I have to fix the decal which then designates where a line starts for a paint detail. Then have to mask over the decal.
My idea is two coats of the Aqua Varnish. But any other ideas & tips will be helpful.
A possibility perhaps, two coats of varnish to seal the decal, then mask the edge with a damp piece of cartridge paper or similar, lifted quite soon after the paint application. I have never tried it, but can’t see why it wouldn’t work. I think you should trial it first though.
After the varnish try post it notes...they are low tack enough not to trouble the decal.
Laurie,
I've avoided this, like the plague! I've usually got round it, by using a tracing of the decal to mark out the paint line starts & finishes, applying the paint, then touching up after applying the decal. If there is no alternative might it be possible to use masking fluid over the decal?
I've done it successfully on this little Jet Provost. The large orange area, with the number 24 on was half masked over to paint the black area above.
So, it was a good goat of varnish followed by a couple of days to dry. Then Tamiya masking tape, de-tacked on my forehead - yes, I know.
Once sprayed, just using very light coats of paint, I removed the masking tape as soon as possible. It worked.
Nice idea Colin. Darned nice model as well. Superb finishes.
Puzzling where do you get your goat varnish :tears-of-joy:
Goat varnish is very exclusive. Best not to ask.........
