Me 109 F4 Trumpeter 1/32
Hi Antonio
Do you spray the future or use a brush? if you spray what pressure and needle size do you use?
Vaughan
\ said:
Hi AntonioDo you spray the future or use a brush? if you spray what pressure and needle size do you use?
Vaughan
Use the airbrush. I make a dilution of 10 / 3 (Future / Tamiya thinner).
Needle 0.4 and about 1.5 to 2 kg. pressure.
Thanks for your answers. I'll paint the spinner and propeller with RLM 70.
Band painted on the fuselage and decals already placed.
An error in the decals. Where it says "night anfassen" should read "nicht anfassen". I was warned before taking the layer of Future to protect the decals. Almost half hour with a brush and water to remove them.
before
now
Good save. Did you get a corrected one, or did you cut the g down to a c?
There are two decals on a sheet of Eduard.
A coat of Future to protect the decals and a wash.
Exhaust smoke and machine guns simulated. Matt varnish applied. This model has served to test some new things. First the "wash" of the MIG now the varnish Gunze mate and liked it.
I corrected the painting of propeller. Now painted with RLM 70.
I glued the landing gear and the lights, I glued the pieces. next to the radiator (do not know the name).
Hi Antonio
That's a fantastic finish very realistic weathering. Well done.
Vaughan.
It's over. Despite the mistakes of the kit has been that I liked to build. To all who commented and helped my thanks.
I hope you enjoy.
Hi Antonio
Another outstanding model.I notice that there is no ariel wire have you yet to fit it?
Vaughan
\ said:
Hi AntonioAnother outstanding model.I notice that there is no ariel wire have you yet to fit it?
Vaughan
Well, the antenna was just glued. After I make sure that is secure I will put the wire.
ariel wire placed.
Great work mate. Looks superb, as always.
Kresten
