MG Magnette Converted
rtfoe
Well-known member
Hi Guys and Gals,
Lately the sweet shop has been flooded with military heavy posts by refugees from a long gone site. Many have hidden affections for non military subjects so much so we sometimes camouflage our builds for that ex-site associating it with a connection to a war movie. I'm happy Scale models site supports any genre. Now the Battle of Britain gave me a chance to model something civilian without infringing on the ex-sites rules. This came in the form of the MG Magnette or whatever that car was that I had to convert as close as possible with and available Airfix kit shown here...
To this...
View attachment 301328 View attachment 301339
It all starts from opening the box and surveying what needed to be cut and replaced. So let the modifications begin...
View attachment 301333 View attachment 301334
The kit although old was quite nice but shallow in detail at certain areas. I noticed the dash board was at an angle for this model of MG and had to be straightened for the movie version.
View attachment 301335 View attachment 301336
The spoked wheels were really good with no flash to clean up at all. I drew some directional lines for cutting and added extentions to the back...
View attachment 301337 View attachment 301340
You can clearly see the amount of cut I had to do for the dash board and it's not even to be straight but with two humps as you will see in the next accompanying photos.
View attachment 301341 View attachment 301342
Here you see the back extention made up from plastic card and thick shims so I could sand the corners round.
View attachment 301345 View attachment 301350
I extended the top also by using a small strip of the existing lip to save on restoring detail.
View attachment 301351 View attachment 301360 View attachment 301361 View attachment 301353
The dash board as you can see is a major modification. I traced out the unique hump shape on a 1mm card strip.
View attachment 301347 View attachment 301348
The strip was attached with some added dials and switches
I've run out of image space so more will come later in the next post.
Thanks Paul. I don't do shiny stuff much and this was really a challenge to keep it squeekly clean. I don't think it's even accurately modified. Just touch and go and for the fun of it.
The actual movie car isn't even WW2 vintage but a model that came out in 1948.
Terrific work my friend. I would also like to know how you manage to post your photos in that way. A lot better than large photos one after the other
Thanks Steve,
The images are smaller than usual. You will have to adjust the image size in Photoshop. These are 576 x 432. They can go smaller to fit three to five images in a row. It's trial and error.
Hi, while the dashboard facing cured i tackled the side louvre that was for the exhaust.
View attachment 301423 View attachment 301424
I then added a lip to the dash board which acted as leather trim and I changed the head for the driver with an appropriate resin one from my stash.
View attachment 301425 View attachment 301426
I replaced thick pla card to the side board edging that was cut away from the modification. Two part putty was used for the dash front and louvre detailing done ala zimmerit with a flat screw driver.
View attachment 301427 View attachment 301428
Extra leftover putty weas spread over the back tarpaulin cover. The louvres aren't exactly state of the art but I was happy with it.
View attachment 301429 View attachment 301430
Lots of puttying and alignment adjustments ahead, something that is expected from an old kit. Such things don't need chucking into the bin 'cos it doesn't align. :smiling4:
View attachment 301431 View attachment 301432
While the putty cured I moved onto the next phase of the build.
Hi Richard,
very nice work so far. I am always very impressed with modifications, and this is no exception
Thanks Marcello, Jimbo, Ian and Gavin,
Seriously a fun build is when it's straight out of the box and finished within the weekend. But these days sometimes the expectations demand a certain level of completeness coupled with wanting to better the next build can be tiresome. Fun for me is if it's scary enough and making the attempt. Just looked at the link...so Douglas did have one of these...cool. Thanks
Hi,
We're now giving attention to the back which was extaended sanded and smoothed down.
View attachment 301925 View attachment 301926
The side doors were given the right contuors and extentions were prepared to make the running boards. Judging by the ink work there was a lot of calculating to be done before bending and cutting the size correctly.
View attachment 301927 View attachment 301928
The pieces were joined and gaps filled up. Meanwhile the doors shapes were scored. Black primer was sprayed in areas to check on blemishes.
View attachment 301929 View attachment 301930
The othe running board was duplicated making sure that it was similar
View attachment 301931 View attachment 301932
Puttying with two part putty made up the rest of the shape of the running board especially towards the front mudguard using my finger and water to smoothen it out.
View attachment 301933 View attachment 301934
Wet sanding and polishing sticks did the rest. Looks crude at this stage but with primer on would look better.
View attachment 301935 View attachment 301936
Thanks for looking in...C & C welcomed.
You’ve got some impressive scratch building modifications going on there, superb stuff :thumb2:
Thanks Jimbo and Norman,
Surprised you've not seen this Jimbo. If it wasn't for the GB that I was building this for, Norman, I wouldn't have scratch built and left it as an OOB build. The original kit itself is a classic.
Hi Richard
I sort of remember the car as a finished model but I've not seen the progress shots.
Just had a good catch up on this one. Some wonderful additions and detailing. How many builds do you have on the go at the moment?
