So, I need to buy a gloss yellow for my ejector seat handle. A whole pot of paint just for what will probably amount to a brushful. Not a major problem though.
Ive already bought a pot of glos red and that I only need about the same amount of that, however, red is often used, normally only a blob or two, but nearly every single aircraft uses it, even if only for the cockpit.
So, one of the next "wishlist" paints is gloss orange. Now, The exact amount I need is minute. A circle 1mm across.
So, Im thinking that I could just get a tile, or some other material that doesnt absopb paint, get a cocktail stick, put a blob of yellow and a blob of red. Both gloss paints, and both by humbrol. Im sure Ive done this before with other colours in the past and my only rules are
do not mix enamel with acrylic
Do not mix different brands. In fact done even mix different types (Model air and model color for example)
So, for the orange Im going to mix red and yellow. It may not be the same as Humbrol number 18 but we are talking 1 tiny blob
But that got me thinking,
Obviously if Im painting a large area, for example a great big 1/32 scale orange galaxy then Id buy the paints proper, but would this work for green and purple. Mixing two primary colours. Obvioulsy when you are talking about mixing greys and white to make a "slightly dark grey similar to a gull who has been on a diet of shrimp" then its best to leave it to the experts and buy the paint. But for a small amount of a basic colour are there any pitfalls?
