Neil Merryweather
As promised I have been conducting tests on how to create the hull with all its rivets (1,064 - ish)
My main concern is the huge number of rivets that absolutely MUST be placed in straight lines and evenly spaced. I don’t have the skill or the patience to do that by hand, so I’ve got to find some way of reliably controlling the placement of them. Also, I want to create the effect of slightly battered metal, so my first instinct was to use thin metal like the copper sheet I used in my Higgins boat build. So, how to create the rivets? I do have a rivet punch, but over a thousand? I don’t think so! Pins, maybe?
I don’t have any with a small enough head(0.65mm diameter in my digital model), and I don’t even know if they exist, but let’s just prove the concept for starters. Now I need to create a straight line of holes at precise intervals, and I remembered my device for planting rye grass in my Fusiliers diorama- the dressmaker’s tracing wheel
I don’t really like the way the pins have dimpled the metal, it’s not appropriate for warship steel plate, but let’s carry on and see what it’s like painted.
I actually like the effect of imprinting from the reverse - the indents are a better size, but they are pierced all the way through. I ran some CA in from behind to hopefully plug the holes so we’ll see how that looks when it’s painted.
Hmm, not bad. The holes are still showing but I quite like the effect. Maybe there’s a way of getting around that. And the dimpling of the pins is not so noticeable.
Next I tried 3D printing the rivets, ready-spaced in a line. I placed them on stalks in a line of 16 on a bar. Here’s the digital model, it’s a lot clearer than I can photograph.
It certainly beats punching over 1000 by hand, but it was tricky to glue accurately and without leaving glue marks (TET). But it might be worth developing further.
I made quite a large sample panel (using 0.5mm PETG sheet because that’s all I have that’s big enough) because I wanted to experiment with ways of representing the welded seams.
I used two thicknesses of thin solder wire and thin plastic rod because the horizontal welds are chunkier than the vertical ones. It seemed like a good idea to try and reproduce the actual process, so I melted them with a soldering iron and laid them into scribed panel lines. I had real trouble gluing the solder until I degreased it - MUST remember that.....
The whole point of this is to test the techniques so I thought I would try drilling multiple holes in straight lines to see exactly how tricky it is. I used the flexible drive on my mini drill(not a Dremel, which doesn’t go slow enough) and amazingly it didn’t melt the plastic too much, I guess because it’s so thin. And it wasn’t as difficult as I expected either. I added a few dents too with various blunt implements.
So how does this look painted?
Kind of ok , but I am not happy with the glued rivets and the weld seams don’t really work.
And I must remember to dust it before I spray it for real....
So the next logical step is to see if I can 3D print the entire panel, rivets and all....
Stay tuned folks....
Neil
Neil
