Just thought I'd share this little golden nugget of info. Call it a public service Bulletin.
When using an electric plane, The woodworking tool, not an RC model. should you be working at an odd angle and you come to drop it
DO NOT TRY TO CATCH IT!!!
I will just point out that they work really well on fingers. I can vouch for that after the Plane had removed the pad of my left hand pointing finger in like 1/5000 Of a second.
On the bright side it didn't hurt at all. It did bleed rather a lot though..
I have just got the kit home for the SIG Tank Busters Build as well. It was hard enough banging in fence staples with an 'ammer, So I cant see me building models for the next few days.!!!!
Hey Ho, the cat prison, (I have closed the covered terrace with netting and built a couple of doors to keep the buggers in. It was during the construction of said doors I dropped the darn plane). is done and the cats are as happy as they can be. So I s'pose it was almost worth it!...?
